Like Tree1Likes
Old 02-15-2007, 02:39 AM   #211
benny, im using standard tamiya radials and they grip well on carpet concreat and tarmac, well i find they do anyway probaly better tyres out there though
D4nny06 is offline   Reply With Quote
Old 02-15-2007, 02:56 AM   #212
Benny Lai's Avatar
Thanks for the reply Danny. What insert do you use? Soft?
Benny Lai is offline   Reply With Quote
Old 03-03-2007, 06:37 AM   #213
Blueshark's Avatar
I'll bet the tires will dig into the chassis..
Originally Posted by rayman
This thread is up so I'll post my current experiment
TT01r rallyweapon with dfo2 tires. Jumping capability unknown.
Blueshark is offline   Reply With Quote
Old 03-03-2007, 06:39 AM   #214
Blueshark's Avatar
Yea, that's what i did and i decided to mount the pinion 1 position less..i.e. for 25T, i use the 24T slot..to get a better mesh position with the spur..using a 13T mod motor now...so fast its hard to control..but the spur does not strip anymore! Rally time now..heh..
Originally Posted by Benny Lai
Check your motor mount chart for correct mounting position if you're changing your gear ratio. Normally strips only occur when the "mesh" are not correct. Hope this help.
Old 03-03-2007, 06:39 AM   #215
Blueshark's Avatar
I'm using stock motor only...but then i it like a buggy....up and down big ramps..and jumps in dirt.. maybe that's why...
Originally Posted by sosidge
Don't strip in my experience.
What motor/hop-up setup are you using?
Old 03-03-2007, 06:44 AM   #216
Blueshark's Avatar
Foams would be best..not sure if that's allowed..where's the TAC07 held?
Hi Guys, can anyone help me out about some tyre issue. As I've mentioned, I will participate in TAC '07 which is a indoor with carpet surface. Kindly share with me your experience which tyre type i.e. slick, semi-slick or radial will give better traction on new carpet? Also, what insert combination. The reason I ask this is to reduce my cost for having too many tyre sets. Thanks in advance.
Old 03-04-2007, 05:12 PM   #217
Benny Lai's Avatar
Foam is not allowed in TAC. Only Tamiya tires. This year TAC final will be held in Taiwan. I'm participating in local qualifying.
Old 03-06-2007, 05:01 AM   #218
Hi all. I'm very new to the world of elec R/Cs and was chasing a bit of advice in regards to my new TT01. At the moment its bone standard except for bearings and shocks.
I will be setting it up as a weekend drift car since the local place doesn't allow nitro's in the drift.
I've already been told that a alloy/carbon tailshaft should be my next upgrade, but I was looking for the name of the part/wheel/cog that I can hear grinding and jumping teeth whenever I go from hard acceleration to braking/reverse.
Cheers.
Droopz is offline   Reply With Quote
Old 03-06-2007, 06:37 AM   #219
ahbock's Avatar
Send a message via MSN to ahbock
Wanting to fix my universal shaft on the front of my TT01 chassis. Current using front one way, adjustable upper arm and steering turnbuckles. I found that the shaft is long that obstruct me from fixing in knuckles on the arms.
I got two questions here
1) do i need to buy a different cup (OP.950) for the front one way to fix the universal shaft?
2) The shaft given in the package is not in the correct length? The number engrave on the shaft is 39
Please help. Thanx.
ahbock is offline   Reply With Quote
Old 03-06-2007, 05:18 PM   #220
Benny Lai's Avatar
Please help. Thanx.
39 is the correct length for TT01. There are 2 type of metal cup for TT01. "Big" cup is for the standard plastic dogbone. There is another "small" one for UJ. Hope this help.
Old 03-06-2007, 08:32 PM   #221
ahbock's Avatar
Wat is the part no. for the Universal shaft cup for the front one way?
Old 03-06-2007, 09:34 PM   #222
Cheers.
Also, can anyone point me at a guide, or tell me how to lock the rear diff in a TT01. Apparently it will also aid somewhat in drifting.
Old 03-07-2007, 12:59 AM   #223
Benny Lai's Avatar
Sorry, I don't know the part no. I'm sure your LHS can assist you on this.
Old 03-07-2007, 01:01 AM   #224
Benny Lai's Avatar
If you're using stock bevel gear diff, you can use thick diff oil to lock it. Hope this help.
Old 03-07-2007, 01:40 AM   #225
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
If you want to lock it. Try using glue gun and inject glue stick inside the gear and cover it and wait until it dries. then try your new locked diff..
nikkiesteban is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
