Like Tree1Likes
Old 11-05-2012, 06:46 PM   #2131
Just curious, and I did search this thread to no avail, but what is the front toe angle when using the non-adjustable steering arms instead of the turnbuckles and ball cups?
Also, what is the camber angle when using the non-adjustable upper arms?
.crispy is offline   Reply With Quote
Old 11-08-2012, 02:59 PM   #2132
Caleb_Bush's Avatar
Trader Rating: 28 (100%+)
Default 3Racing Roller Chassis with Electronics
If anyone is interested, checkout my for sale thread:
Tamiya TT01E 3Racing Conversion Roller with FF03 Spur Gear Modification
It's pretty much setup for drift.
Caleb_Bush is offline   Reply With Quote
Old 11-11-2012, 04:16 PM   #2133
f.bence's Avatar
There is plastic bevel gear? Alu is too heavy. Any idea?
Thanks!
f.bence is offline   Reply With Quote
Old 11-14-2012, 01:08 AM   #2134
devilfish's Avatar
I finally got an email the other day from Active Hobby to say they had new stock of the "Counter Drift Unit" which allow for counter steer drifting, I just purchased one so should arrive early next week. I'll post my thoughts when it arrives. If anyone else is interested:
1.5 Version: http://active-online.ocnk.net/product/191
2.0 Version: http://active-online.ocnk.net/product/190
devilfish is offline   Reply With Quote
Old 11-14-2012, 01:08 AM   #2135
devilfish's Avatar
Old 11-18-2012, 12:46 PM   #2136
I have a TT-01R Type E. I want to add sway bars. How do I do that?
The sway bars say I need the Carbon Upper. But the Carbon Upper says it doesn't work with the Type E...
What do I do?
Old 11-18-2012, 03:27 PM   #2137
What do I do?
the tt01 was not designed for sway bars so you cant add them.. its entry level...you would have to customize if you want to add them....
rescue119 is offline   Reply With Quote
Old 11-18-2012, 06:24 PM   #2138
Starteur's Avatar
Look at your manual , there are sway-bars for your car!
You need 2 front kits ( 1 for the front and 1 for the rear)
If you want to be sure check Tamiya's website.
You don't have to customise........
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 11-18-2012, 07:22 PM   #2139
sry i was going by my tt01-e manual.... but i see it in the tt01r-e manual
only for the front as well
http://www.tamiya.com/english/rc/manuals.htm
Old 11-19-2012, 03:53 AM   #2140
Starteur's Avatar
Look carefully you use the front kit for the rear.
Old 11-19-2012, 04:19 AM   #2141
There is definitely something weird going on. The TT-01R Type E manual shows the sway bars being attached to the lower arms (using two front kits).
However the "kit" that is available from Tower shows different parts and matches up to the install method shown here:
http://media.photobucket.com/image/r...o/DSC01340.jpg
I have the Carbon Upper and the attachment points on the upper arms, so I think either method will work.
I'm guessing that the upper arm method was the original way and when they came out with the new TT-01R Type E they came up with a method of attaching sway bars to the lower arms since they already had added the new solid plastic brace up top.
Old 11-26-2012, 02:01 PM   #2142
rctoyguy's Avatar
Trader Rating: 21 (100%+)
I'm sure it's somewhere in the 140something pages here, and I have tried searching the thread and even going through page by page to find it - but can someone help me to know what I need and how I do the spur gear mod?
I am setting up a TT-01 for my son to race in VTA, and I need to get to a FDR of 3.9 or so - there is just no way to get close to that with TT-01 spurs/pinions, even if you can find them anywhere, and someone somewhere mentioned that there is an adapter or mod that will let you run other spur gears for more gearing options.
I'd prefer not to make permanent modifications, to the chassis, because I would also like to get the car back to TCS legal for the occasional TCS race.
I had hoped to have his car ready by this weekend, but it's not looking like I'm going to make it.
Jeff
rctoyguy is offline   Reply With Quote
Old 11-26-2012, 02:36 PM   #2143
SteveM's Avatar
Trader Rating: 130 (100%+)
All you need is the blue aluminium spur gear adapter from the Tamiya FF-03, part number 54234. You will need to drill it to the size of the TT-01 shaft and a drill press really helps with getting the hole perfect. Check out the pictures I posted on RCTech.net and look for post #2076 in the TT-01 thread.
SteveM is online now   Reply With Quote
Old 11-26-2012, 08:08 PM   #2144
rctoyguy's Avatar
Thanks - it looks like my first step is to find that adapter. I had someone else mention running the adapter and then I think it was F201 spur/pinion set (I'd have to look back at the PM or email the info came in) - but that would keep Tamiya gears and the odd pitch, making pinions harder to find wouldn't it? If I wanted to go to a more standard gear pitch, does anyone have any suggestions on spurs that will work on this adapter?
And - can you continue to use the stock motor mount? Is there a set of holes that will give proper gear mesh? I've seen mention of fabricating a motor mount, but I'm not much of a fabricator.
Jeff
Last edited by rctoyguy; 11-26-2012 at 08:56 PM. Reason: Added motor mount question
Old 12-04-2012, 09:04 PM   #2145
So I recently installed my 3 racing conversion, well my Celica GT body I spent months setting up the lights on. It no longer fits the wheelbase is way to short, does anyone know of a nice body I can get for it now?
tabrown is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
