TT-01 Forum
#2101
What is a good dog bone replacement
#2102
#2103
Tons of questions, one Anyone have the 3 racing chassis conversion? How do you like it, two I got a 200mm body (celica gt) and I want the rims to actually sit somewhat flush. I was thinking like a 8.5 mm offset. Also, blew my esc. What would a CHEAP brush-less replacement be? I am new to the drift scene been into off road majority, so any help is appreciated!
#2104
3Racing Conversion TT01E
For me, the conversion is awesome. I followed jhwnissian's lead and used the FF03 spur adpt. to gear the car down to an FDR of 3.86 (52 spur/35 pin.). Using a 21.5T motor, I can hit speeds of 31mph. Works really well with the 3Racing solid axle on the back and front one-way axles. Only drawback is the the .6mod gears make the car sound like a diesel truck!
#2105
#2108
So Steve m how are those gears holding up for ya ? Did the ff-03 mod eat any gears ?
Should I change the friction shocks out ? I only run on carpet
Would jaco blues tires help on carpet or is their a better choice?
Besides bearings and drive shaft what other mod should I do for carpet racing?
Thanks for any help
Thanks for any help
#2109
The current setup, well it's on three separate pieces lol. I was running I believe the stock spur and an 18t, with a 19tx2 motor. She drifted beautiful and never got hot. The chassis on the diff case cracked so I thought to get the 3 racing conversion.
#2112
what spur can i use from Robinson's Racing? I got a TT01 stock, would like high rpm
#2114
what you mean? if you use the ff-03 mod you can use a lot of gears
48p or 64p
dzinehaus most of the guys like to use the 64p cuzz they are smaller
and you dont have to cut up the case
Im putting a 58516 chassis together and would like to know how well the stock slicks work?
48p or 64p
#2115
48p or 64p
48p or 64p
