Like Tree1Likes
Old 10-26-2006, 02:03 AM   #196
Blueshark's Avatar
Default Hi
Hi all!
New to this thread, I've posted some pictures of a TT01 Rally mod as well as a TT01 Buggy and TT01 MT Mod (Just with RC10 MT wheels).
Let me know what you think.
Thanks all!!
Here's the thread:
1/10 RC RALLY
Blueshark is offline   Reply With Quote
Old 10-27-2006, 05:48 PM   #197
Blueshark's Avatar
Default Added Pics
Added some more interior pictures of the buggy mod in the same thread as a/m.
Thanks!
Old 11-03-2006, 08:20 AM   #198
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
Talking
Aloha all, would anyone have a good starting point on setup for my son's new TT-01R. It has trf shocks and the carbon upperdeck, we plan on running in the TCS with the silver can motor. any help would be great.
Thanks.
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 11-03-2006, 08:37 AM   #199
larrio's Avatar
Thanks.
What class of TCS? The SPEC class is very limited in rules and hop-ups for the TT-01. (stock gearing, tires, etc)
A good base point is box stock, drive it and then make corrections depending on the handling characteristics of the car. Different tires, inserts, track surface, and track temperature will have an effect also.
larrio is offline   Reply With Quote
Old 11-03-2006, 09:38 AM   #200
Thanks bro!
Old 11-03-2006, 10:23 AM   #201
larrio's Avatar
Thanks bro!
Remember that different bodies will make the car handle different also. General rule of thumb is to run the toe-in rear uprights for hi speed stabililty entering the turn. Use yellow springs all around as a base point, check the camber of the tires with a camber gauge or just look at how they are wearing out.
Small adjustments in increments and you should be fine!
Old 02-05-2007, 04:37 AM   #202
Blueshark's Avatar
Default Spur gear stripped
Does anyone know why the spur and pinion always strip? Managed to strip 3 spurs and 2 pinions in less than an hour!?
Old 02-05-2007, 05:01 AM   #203
sosidge's Avatar
Don't strip in my experience.
What motor/hop-up setup are you using?
Old 02-05-2007, 05:22 PM   #204
Benny Lai's Avatar
Check your motor mount chart for correct mounting position if you're changing your gear ratio. Normally strips only occur when the "mesh" are not correct. Hope this help.
Benny Lai is offline   Reply With Quote
Old 02-08-2007, 06:03 AM   #205
raffaelli's Avatar
I am going to run my TT-01 in the Mt Laurel (parking lot) TCS this year in the Spec or GT class (probably spec). Can someone give me a starting point for the set up?
I have been running this in a local spec class where we must run it box stock on carpet with rubber...lots of fun.
24ITA
raffaelli is offline   Reply With Quote
Old 02-13-2007, 10:05 PM   #206
Benny Lai's Avatar
Attached is the pictures of my TT01 R-Spec. I will race this car at Tamiya Asia Cup '07. Stock TT01 class.
TT-01 Forum-nismo-r34z-19.jpg   TT-01 Forum-nismo-r34z-21.jpg   TT-01 Forum-tt01-r-spec-00.jpg   TT-01 Forum-tt01-r-spec-01.jpg   TT-01 Forum-tt01-r-spec-02.jpg
Old 02-13-2007, 10:56 PM   #207
Benny Lai's Avatar
Some more pictures.
Old 02-14-2007, 02:47 AM   #208
asil's Avatar
Send a message via MSN to asil
Hi Benny, great car.. wish you good luck.. is that too much clearence dissappeared with alu.steering linkage set?
Asil
asil is offline   Reply With Quote
Old 02-14-2007, 05:40 PM   #209
Benny Lai's Avatar
Asil
Thanks. Do you mean that the steering set will reduce the freeplay on the steering? If yes, it did make a big difference. Couple with the steering turnbuckle set with a little bit toe-out with give you very good straightline stability.
Old 02-14-2007, 05:46 PM   #210
Benny Lai's Avatar
Default Carpet Tyre selection
Hi Guys, can anyone help me out about some tyre issue. As I've mentioned, I will participate in TAC '07 which is a indoor with carpet surface. Kindly share with me your experience which tyre type i.e. slick, semi-slick or radial will give better traction on new carpet? Also, what insert combination. The reason I ask this is to reduce my cost for having too many tyre sets. Thanks in advance.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
