Like Tree1Likes
Old 09-16-2011, 06:12 AM   #2011
Originally Posted by mon View Post
My kit is a Tamiya TT01 with a spur- pinion of 58/23 and a Tamiya TEU 104BK with Tamiya brushed 28T GT tuned motor during my last 5 bashing sessions I already damaged 2 ESC what could be the problem ?
Are you drifting or running with grip tyres?
Are you running a heatsink on your motor? Not really related to the esc but worth knowing
What battery are you using and what ratings and voltage does it have?
mr lee is offline   Reply With Quote
Old 09-20-2011, 01:56 PM   #2012
Bill Zone's Avatar
some pics of the finished kits..
still have a 2006 BMW touring body with LEDs to do..will trade for a 190E if anyone has one..
Bill Zone is offline   Reply With Quote
Old 09-21-2011, 01:44 AM   #2013
They look neat!
A drifter and a racer or both drifters?
Old 09-21-2011, 10:56 AM   #2014
Bill Zone's Avatar
Originally Posted by mr lee View Post
They look neat!
thx! sold one to my buddy and they are both racers at the moment!
Old 09-23-2011, 08:39 PM   #2015
Originally Posted by tdunster View Post
Here's the bad news - It's a little bit you but it's mostly the car.
Putting a spool on the front will make the car a hell of a lot easier / more predictable. to drive.
If the Ball Diffs are slipping that will cause problems as well.
Get someone to hold the front wheels while you turn the rear wheels. All wheels should emit even pressure / force (You don't want one wheel turning on its own). If not the car can be very unpredicatable under hard acceleration.
Some decent tires will make a big difference as well.
600 Oil in the front dampers might help you as it will produce understeer.
Red springs on the rear will also induce some understeer - although the car might also bottom out so be careful.
Overall though I think a spool will make things a lot better for you.
hi can advise what you mean by putting a spool on the front?
I have some handling issue for my tt01 R type e.
when turn into corner, car will oversteer. if i slow the car down, while exiting the corner with full throttle, can will have spin...
wrxmacorona is offline   Reply With Quote
Old 09-24-2011, 09:37 PM   #2016
Hi Guys, new to the hobby and having a blast. Just got a quick question in relation to the TT01. Any assistance would be awesome.
I have the :
Hitec 311 cheapo servo
tt01ED
Eurgle GT3B 24Ghz Tx/Rx
Tamiya Sports Tuned Motor
Stock ESC
Since installing the Hitec Servo, any minor accident that involves the front end causes the wheels to lose their center and move to the right. I still have control but the "new" centre for the servo is way off to one side.
The fix is apparently to pull the servo out and re-allign the horn. This is not difficult but has already put a premature end to driving a couple of times.
Sounds like a dodgy servo? Time to buy another? I started on the MG996R Metal Gear Digital Torque Servo MG995 RC CAR 1/8, but found it problematic. If I do have to upgrade, what is the next best thing in a similair price range?
hoardz01 is offline   Reply With Quote
Old 09-25-2011, 12:21 AM   #2017
Tamiya dont make a servo horn for hitec servos.
The best bet would be to replace the servo with a futaba compatable or jr compatable servo and istall the correct servo horn
burnouts is offline   Reply With Quote
Old 09-25-2011, 01:31 AM   #2018
Default midship
anybody know where i can find TT01 midship conversion? (either Active Hobby's STR081 or Eagle's)
ju5t1n is offline   Reply With Quote
Old 09-25-2011, 02:58 AM   #2019
mingnon's Avatar
only place i found is
http://banzaihobby.com/index.php?mai...ducts_id=10684
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 09-25-2011, 06:14 AM   #2020
Thankyou for the reply, much appreciated. The horn didn't seem to be a very good fit, from what you have said I guess it's same to assume that the slippage is occuring in the horn when impact occurs. Oh well, I'll grab a futaba and see how that goes.
On a more positive note, locked up the rear diff while I had the car apart to do the servo. Big improvement in drift.
Old 09-26-2011, 08:26 PM   #2021
Default New TT01 ?
Hi guys ,
I am looking to get a new car for my son.
Are there any rumors of a new TT 01 coming out ? Or a replacement for Tt01 ?
Or will it still continue for next year or two at least ?
Thanks !
gimpex is offline   Reply With Quote
Old 09-27-2011, 02:34 AM   #2022
Originally Posted by gimpex View Post
Hi guys ,
Thanks !
Don't think Tamiya will ever drop the TT01.....bang for buck you cannot beat it!
The demand is too high for it so they would be stupid to drop it.
The Type E is the enhanced version which is an improvement over the older one (steering definately better) but all parts from the old and new are interchangable so no need to worry.
I really don't think they will change it in the next five years....they may just update it......but who knows. At least there does not apear to be anything on the cards for the next year at least.....they would rather spend their time developing newer models.
Old 11-09-2011, 08:16 PM   #2023
Me too, please explain what is "spool"?
b.wihardja is offline   Reply With Quote
Old 11-15-2011, 07:20 AM   #2024
Differential Locker.
Either aluminum, welded some how, diff locker grease, silicone chaulk stuffed in there for a true lock, etc etc etc. There are many ways to lock up the front differential or rear for that matter.
Locking has it advantages and disadvantages. IMHO for the new, rookie driver, diff locking isn't something they should be getting into on the TT-01. I feel it's more of something for an advanced seasoned controller as it produces a considerable amount of understeer amoung other things. The only advantage is late breaking which is really not to much of an advantage since most times your only pressing the brake a fraction of a second after the driver behind you, not enough to make any real difference on the track and exit control since both wheels are pulling at the same time it makes getting out of the corner better.
Tire wear will be come a great issue, setup and maintain of suspension will be a task getting it to the sweet spot to try and remove most of that understeer you created etc. Again, I would recommend it for any seasoned driver, but def not for a rookie or beginner.
This of course is just my humble .02 cents since I too spooled my front one my tt-01 the day after I got into RC cars and I fought it for months before the local track legend had me swap it back out to stock, make some suspension adjustments and presto, track times as well as skill improved 10 fold for corner management. Again, just my .02 cents from one rookie to another.
Creativeindy is offline   Reply With Quote
Old 11-18-2011, 07:35 PM   #2025
Oh now I know, thank you so much
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
