Like Tree1Likes
Old 05-09-2010, 09:21 PM   #1831
Timbulb's Avatar
I've never seen it.
Timbulb is offline   Reply With Quote
Old 05-10-2010, 03:47 AM   #1832
Default sport tuned estimated speed
Hi all, what speed do u estimate the following car will achieve, specs are :
Tamiya Sport tuned motor
Full bearing set
Alu shaft
i) 55/25 Spur/ pinion set = 5.72 gear ratio
ii) 24/58 Spur/ pinion set = 6.28 gear ratio
3300 mah nimh batteries
Car weight is 1.590 kg and body is a Nissan Nismo GT-R R35 with Silica Radial tires.
Waiting for your guestimates please.
Thank you
cpk1 is offline   Reply With Quote
Old 05-14-2010, 04:56 PM   #1833
Full bearing set
Alu shaft
Thank you
21-27mph
27.52mph max calculated speed with 55/25 gearing, 64mm Dia. tires and 21000rpm motor
beast_C_A_T is offline   Reply With Quote
Old 05-25-2010, 01:26 PM   #1834
Suspended
Originally Posted by beast_C_A_T View Post
21-27mph
wow 27mph, probably on a velodrome, not sure a TT01 can reach that speed on an R/C track. specially where we play>> basketball court "slash" R/C track.
cheech&chong is offline   Reply With Quote
Old 05-30-2010, 07:37 PM   #1835
bencason's Avatar
How well does the TT-01 handle motors that are more powerful than the silver can that comes in kits?
I have some old 27T stock motors [these may not be that much stronger than the new silver can motor I have ] plus a 19T mild mod. motor that I would like to use to build skills for a move to a 21.5 brush-less sedan spec. class. However, I don't want to tear up anything in the TT-01 since I will use it in a different spec class in the Fall.
bencason is offline   Reply With Quote
Old 05-30-2010, 07:50 PM   #1836
MD
MD's Avatar
Trader Rating: 111 (100%+)
I ran a Traxxas Stinger 20T last summer and it handled fine. I ran x-pattern pro tires.
MD is offline   Reply With Quote
Old 05-31-2010, 03:37 PM   #1837
bencason's Avatar
Thanks, that is good to know. I had heard the TT-01 was pretty durable but first-hand experience info. is best.
Comparing the TT-01 to the TT-01E, it looks like the E has some steering & suspension adjustments [the manual has an actual set-up section for toe-in/out and camber!] that are not there in the base TT-01. I have seen a list of the parts to upgrade the base TT-01 to the E model but it looks like it would be cheaper just to buy a second-hand E model and use my base model as a parts car.
The Spec class I will run in has strict limitations on the hop-ups and uses hand-out motors but does allow either version of the TT-01.
Are these adjustments on the E model of insignificant effect or am I going to be wishing that I had kept looking until I found a 2nd-hand E model?
Old 05-31-2010, 03:45 PM   #1838
MD
MD's Avatar
This place has some TT01E's at a reasonable price and it's in the U.S. There shipping is a little high. So, you may want order some other things like motor cleaner, oil, etc.
http://www.rocousa.com/DETAIL.ASP?PRODUCT_ID=TA58449
Old 05-31-2010, 04:35 PM   #1839
bencason's Avatar
Hmmmm, more good info. I spent almost that much on a 2nd hand TT01 [at least it has all the hop-ups allowed by the Spec class].
Too bad I didn't do better research before I bought the TT01. Had I done so, I would have held out for the TT01-E with tighter steering & the adjustments for toe, droop, camber and shock positions [at least I think these are all available after reading the E manual].
At this point, I'll just give the base model a chance and see what I have. The playing field may be leveler than I fear. If I am at too much of a disadvantage, I'll just sell the TT01 and run my M03 Mini in a different class.
Old 05-31-2010, 06:28 PM   #1840
Ultimate Hobbies has the tto1 type E R for 119.95
SPEEDRACER48 is offline   Reply With Quote
Old 06-13-2010, 05:16 AM   #1841
Default IFS only bodies?
I have been told that Tamiya makes a carbon front shock tower that has a lower profile which allows the use of bodies that only fit the TA-05/TB-03 chassis with IFS shocks. Can anyone confirm this and give a part number?
woodys3b is offline   Reply With Quote
Old 06-14-2010, 04:13 AM   #1842
knd
3Racing (#TT01-E32) Graphite Shock Tower Stiffener For TT-01E
don't know if this is the one.
knd is offline   Reply With Quote
Old 06-14-2010, 06:53 AM   #1843
bencason's Avatar
This part set is available from Tamiya but I could not find a statement that it allowed the use to the bodies that you are interested in.
54059 Tamiya TT-01E Carbon Damper Stay (Front)
The RC cars are in storage but not forgotten
One of these days, I'll be back to racing... somewhere
Old 06-14-2010, 09:07 AM   #1844
Ageofdeath10's Avatar
It definetly does handle more than the silvercan! I had a 10.5t Brushless motor in their with only an alloy driveshaft and it handled fine
"Practice makes perfect but nobody's perfect so why practice?"
Ageofdeath10 is offline   Reply With Quote
Old 06-18-2010, 07:12 PM   #1845
im going to be putting in a CC 5700 in my TT-01...what am i going to break??
2Revos 3.3/ 4Tec
Rustler VXL / HPI Flux
F1Pro CC4600 / TT01 CC5700
2XRevo is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
