Like Tree1Likes
Old 04-29-2010, 01:53 PM   #1801
stitchy's Avatar
what motor? easy fix might be the aluminum center shaft.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 04-29-2010, 02:03 PM   #1802
im using speed passion drift master turbo.
is theres any solution for this?
jay
jay568424 is offline   Reply With Quote
Old 04-29-2010, 02:08 PM   #1803
MD
MD's Avatar
Trader Rating: 106 (100%+)
If you are running a faster motor than the stock silver can motor, the stock drive shaft will warp and bend.
MD is offline   Reply With Quote
Old 04-29-2010, 02:11 PM   #1804
all the option parts is installed on the car, even the alu drive shaft
i try o post the picture now
jay
Old 04-29-2010, 02:17 PM   #1805
RC MARKET's Avatar
Drift parts
http://rcmarket.com.hk/product_info....oducts_id=8359
RC MARKET is offline   Reply With Quote
Old 04-29-2010, 02:19 PM   #1806
Originally Posted by jay568424 View Post
i got a problem in my tt01, at full speed, there's a vibration on the center shaft, the car is brand new, at break also and apply power, there a gear sound and like gear locking,
do you have any solution for this.
thanks
by the way its full ball bearing also
jay
Old 04-29-2010, 02:21 PM   #1807
Originally Posted by RC MARKET View Post
is the gear and pinion metal of plastic? wats the quality?
jay
Old 04-29-2010, 03:31 PM   #1808
MostWanted4TEC's Avatar
Send a message via AIM to MostWanted4TEC
thanks
is the car rtr by chance? and I know with mine I had to put mini o ring spacers in my shaft to stop vibration bc I have the aluminum Tamiya shaft and it was alil noisy and it helped. if that don't work check ur rear gear assembly. before I went ball bearing I have a bushing eat away part of the case. HOPEFULLY that's not your issue.
Tamiya TT-02|Factory RC10R5|TC
The way to gain a good reputation, is to endeavor to be what you desire to appear. - Socrates
MostWanted4TEC is offline   Reply With Quote
Old 04-29-2010, 03:39 PM   #1809
also I was wondering what everyone uses for gearing and power plants?
I have the 17.5 novak havok for RCGT with 25t pinion an 55t spur. I still have a lot of low end and was wondering if anyone knew any more parts that could gear the TT-01 up without blowing gears
Old 04-29-2010, 04:13 PM   #1810
stitchy's Avatar
try the 28 tooth pinion by HPI...look a few pages back
Old 04-29-2010, 04:28 PM   #1811
THANKS!! Ill give it a shot!
Old 04-29-2010, 06:13 PM   #1812
Timbulb's Avatar
Well that's total balogna. My club uses black cans and I've tried my 13.5 in my TT01 and it was fine.
Timbulb is offline   Reply With Quote
Old 04-30-2010, 04:43 PM   #1813
thanks
Hi Jay,
You seem to have a brushless system... is it sensorless?
If it is, the gear locking that you experience maybe cogging, very common on sensorless type BL motors.
There are some common causes for cogging:
- low Final drive ratio for motor and car wheight (high T pinions, low T spurs)... try to lower the pinion and check if it still happens
- battery has little discharge capacity (cannot give constant feed to what the motor requests)
- ESC programmed to Agreessive timing...
As for the center shaft vibration... check for play...
is it stock plastic? (may be weared as your motor has high RPM) (Ok forget this i saw you have alu parts)
tamiya alu Hopup parts? (try to put little o.ring in the drive shaft cups)
For example using shaft from tamiya and shaft cups from YR makes terrible shaft connection.
Hope this helps somehow.
hybridM3 is offline   Reply With Quote
Old 05-01-2010, 08:54 AM   #1814
Tsquare's Avatar
Originally Posted by rays_tt View Post
here u go enjoy =) i found that the 58t spur goes really well with the 23t pinion for racing, but i drift with tt01 now so i found that stock gearing is just fine as you need the torque
I know this was posted ages ago, but thanks for the chart.
Tsquare is offline   Reply With Quote
Old 05-01-2010, 01:47 PM   #1815
wow your correct, its the motor programed in aggressive setting.
and yes it is sensor less
thank you so much, i just make it to normal setup
so happy to drift sideways hard
heheheh
thank u again
Originally Posted by hybridM3 View Post
Hi Jay,
jay
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Tags
drift
