Old 08-19-2006, 11:55 AM   #166
Talking
well in the 5 mins i have had since the last post i have nocked up a new chrome centre exit exhaust!!
what do you think???
i quiet like it
creamsodauk is offline   Reply With Quote
Old 08-19-2006, 11:57 AM   #167
Well i forgot to post the pic so here she is
Old 08-19-2006, 12:49 PM   #168
in2deep's Avatar
Talking tt01 and the gang.
this is my TT-01 and some of my other cars.
TT-01 Forum-img_3695.jpg   TT-01 Forum-img_2498.jpg   TT-01 Forum-img_2508.jpg   TT-01 Forum-img_4893.jpg   TT-01 Forum-img_5036.jpg
in2deep is offline   Reply With Quote
Old 08-19-2006, 05:36 PM   #169
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Originally Posted by Blackwrench™
Try to tightenen it just enough before it came loose again and put a soldering Iron on the top of the screw. heat it up just enough that you can move the srew while its hot, and then let it cool down. works fine with us.
thanks heaps mate...it worked!
surrealmaterial is offline   Reply With Quote
Old 08-21-2006, 05:17 AM   #170
hi will this part fit my tt01?? i have the alloy steering set installed, and think i set of tie-rods would be better than the satndard plastic parts
cheers
Tamiya 4WD/FWD Touring & Rally Car Turnbuckle Tie-Rod Set, Part No's. 53191
Old 08-21-2006, 02:08 PM   #171
Unhappy
hi i just took my new built tt01 out for a drive and, i cant say im impressed
i have put a 22t pinion on with standard gearing and added my 19x2 motor, but it seems slower all round as compared with my tl01?? my tl seemed faster in acceleration and top speed(i was using a 19t pinion on my tl01 with standard gearing)
should i install my speed tuned gear that i have purchased or go back down to a 19t pinion as i dont think my motor is fast enough for these tuned gears and the 22t pinion??
any advice you can give me??
19t pinion with standard gears, or 22t pinion with speed tuned gears?? remembering that its running a 19x2 modified motor and a gp3000 battery
please help me
Old 09-07-2006, 05:11 PM   #172
pininfarina's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to pininfarina
Lightbulb
maybe you should just change the motor...
I am using novak 5.5.R brushless with stock gear setup, 19/61..
and this thing really moves!
"Slow down and enjoy life. It's not only the scenery you miss by going too fast, you also miss the sense of where you are going and why." - my showroom below :-)
http://www.tamiyaclub.com/showroom.asp?id=9264
pininfarina is offline   Reply With Quote
Old 09-07-2006, 05:14 PM   #173
Lightbulb Nismo Coppwemix Silvia - TT-01
picture of my ride...
very bright LEDs
Old 09-07-2006, 07:05 PM   #174
mailboxck's Avatar
please help me
Buy the speed tuned gear set. It's a must.
The touring car turbucle set will not fit your tt01. There is a turnbucle set solely for the steering of the tt01 and an adjustable upper arm set as well.
mailboxck is offline   Reply With Quote
Old 10-08-2006, 01:43 PM   #175
Angry
right my car decided to stop today!! i started to drive away car seemed fine, then stop!!! nothing
esc still lights up and you can see the lights changing indicating the car is recieving signals. but the motor wont spin. i put a stock motor in and away she goes, so why did my motor just stop??
could it need new brushes or somthing??
please help as i jus ordered a load of gpm parts (waiting for delivery) and i just installed a new esc to take a bigger motor.
p.s my esc is forward only and came with a resisitor to stop the esc going bang if it goes backwards from a crash as im still accelerating. is this a must to install or not??
Old 10-08-2006, 05:48 PM   #176
Check to see if one of your brushes are hung up. Not making contact with the com.
Sponsers; None, Just in it for the fun!
hdsport82 is offline   Reply With Quote
Old 10-09-2006, 07:09 AM   #177
yep that was it the wires the brushs are attached to wer all tight and scrunched up so i un tightend them jus pulled them apart a little and the motor kicked in again!!!!
happy days lol
how long should a set of brushs last?? and do u think i should have mine changed for peace of mind??
oh and any ideas about the resistor on the motor for a forward only esc?? should i get it done??
Old 10-09-2006, 07:12 AM   #178
oh another thing!! will a set of tl01 dogbones fit in my tt01?? because the tl uses steel ones and the tt's are plastic with metal nibs??
Old 10-09-2006, 07:58 AM   #179
bizkit1's Avatar
Trader Rating: 27 (100%+)
Just get a set of TT01R ones. They're the way to go.
bizkit1 is offline   Reply With Quote
Old 10-09-2006, 08:14 AM   #180
any idea wher from??? im in the uk and have ebay etc?? can you buy the whole set ie the drive cups and so on??
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
SEO by vBSEO 3.5.0
