Old 01-25-2010, 07:40 AM   #1741
UrabusDenis's Avatar
So did I , it doesn't sound neccesary to me....
You guys run LIPO on TT-01 without out any modifications and without any problems?
UrabusDenis is offline   Reply With Quote
Old 01-25-2010, 09:03 AM   #1742
Timbulb's Avatar
The rounded edge hard cases that fit in an M-chassis work well.
Timbulb is offline   Reply With Quote
Old 01-25-2010, 09:53 AM   #1743
stitchy's Avatar
I run the Orion 3800 lipo. Fits perfectly
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 01-25-2010, 06:21 PM   #1744
skiptomylou6's Avatar
Stitchy has the most hooked up TT01.
skiptomylou6 is offline   Reply With Quote
Old 01-25-2010, 08:22 PM   #1745
rough512's Avatar
Originally Posted by UrabusDenis View Post
A question about LIPO conversion
A friend of mine suggests that I cut the "ribs" of the place where the battery would go (to flat it out).He says that the vibrations caused by those ribs could damage the battery. I have a normal 7,4 LIPO (not hardcase)
Do you think this is necessary?
Your friend may have point although it's not those ribs that are causing vibrations. The normal vibrations from the motor, the uneven track surface, warped wheels and the bumps caused by going over kerbs and barriers may force the ribs to dig into the soft-cased pack. With the whole pack resting on those reletively small ribs, this is is not hard to imagine
rough512 is offline   Reply With Quote
Old 01-26-2010, 08:59 AM   #1746
So do you suggest I even the surface? Since I am using the car for rallying so I guess there will be a lot of vibrations
Old 01-26-2010, 04:28 PM   #1747
What do I have to upgrade on the chassis to run a strong engine (let's say brushless) ? I mean that the engine doesn't destroy the car
Old 01-26-2010, 04:47 PM   #1748
stitchy's Avatar
Aluminum center driveshaft and bearings for sure.
Old 02-01-2010, 09:21 PM   #1749
Starteur's Avatar
Is Taniya ever going to make alu. front uprights for the TT01 Type E?????
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 02-02-2010, 02:29 AM   #1750
coorect me if i'm wrong, but i don't think tamiya produce any aluminum uprights for tt-01, hope this helps.
regards,
Marzuk
marzuk is offline   Reply With Quote
Old 02-02-2010, 08:32 PM   #1751
Starteur's Avatar
I know, I was just asking if it was in the plans!
Thanks anyway.
Old 02-11-2010, 12:43 AM   #1752
ZiG-87's Avatar
Does anyone have a spare tt-01 tire foam insert handy? I really need to know the dimensions. Racing on Saturday and I kinda need tires, and none of the LHS have the foams in stock, so I'm gonna cut my own.
Thanks.
ZiG-87 is offline   Reply With Quote
Old 02-27-2010, 08:42 PM   #1753
Default Sloppy steering and ball wear
I've always thought my tt-01 had pretty loose steering. It's not super bad but I've noticed some chassis seem to have a lot less play in them when you grab the wheels and give them a wiggle.
I noticed the play was getting worse a couple of days ago and unscrewed the bit where the front lower and upper arms are connected to the knuckle/uprights. The plastic balls/P7 part (which I've found from looking at other people's chassis are often made of metal) are super worn. This is causing the knuckles and subsequently the front wheels to sit much closer to the ground than they normally do and leads to the suspension only having 4-5 mm of travel before the chassis bottoms out at the front.
My two questions are:
1) Does anyone know what these ball bits are called and if there are any metal replacement balls I can get for the TT-01? I've had a browse on RC mart but haven't had any luck so far...
2) Also, I've read about steering linkage hop-ups (I assume to tighten the other general play in the steering) but haven't been able to find any on RC-mart. Has anyone seen these for the TT-01?
Cheers!
LargePiece is offline   Reply With Quote
Old 02-28-2010, 02:35 AM   #1754
heres the pic
1101 is offline   Reply With Quote
Old 02-28-2010, 06:24 AM   #1755
MD
MD's Avatar
Trader Rating: 105 (100%+)
To improve your steering you can try the TT01E steering rack.
MD is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
