Old 07-29-2009, 04:08 PM   #1561
monkeyracing's Avatar
Originally Posted by cheech&chong View Post
hey guys have you tried, removing the 2 rear dogbones
off the TT-01, just to make it a FWD car?
just curious, I mean, better to ask first, rather than regret the outcome.
Yes, and it's a complete pig.
I did however, get stuck running it as a RWD car one day. It worked pretty well that way, but you really have to watch your throttle when exiting corners. Definitely had more speed, probably due to lower driveline losses.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 07-30-2009, 01:00 PM   #1562
Suspended
Default Thanks MD & monkeyracing
thanks MD for the info,
&monkeyracing- RWD huh!? yeah better try that.
cheech&chong is offline   Reply With Quote
Old 08-01-2009, 01:30 PM   #1563
Hello,
I just picked up one of these and I see people are using the carbon fiber upper deck. Can this be used on the E model? or is the new top deck on the E equivalent to the carbon fiber top deck?
If so, can you use the sway bars with the new E deck?
fetznerX is offline   Reply With Quote
Old 08-01-2009, 01:42 PM   #1564
MD
MD's Avatar
Trader Rating: 105 (100%+)
I have had a TT01 with the graphite upper deck, and I currently have an "E." I think they are similar, although the "E" upper deck may be just a fraction heavier. I can't answer your second question.
MD is offline   Reply With Quote
Old 08-02-2009, 01:22 PM   #1565
Anyone running these in VTA with 21.5? If so, how are you gearing it?
Old 08-05-2009, 11:21 AM   #1566
Suspended
Default TT-01 on rally set-up??
anyone of you guys done it?
and how does it compare to a buggy?
BTW can I see your rally pics
Old 08-07-2009, 05:09 PM   #1567
Mini Racer 95's Avatar
does anyone know where you get the parts for the back end gear part
Austin
Mini Racer 95 is offline   Reply With Quote
Old 08-07-2009, 06:49 PM   #1568
MD
MD's Avatar
Get the part number and put tam in front of the number and google it.
Old 08-09-2009, 02:27 PM   #1569
it is the rear spur gear
Austin
Old 08-09-2009, 06:56 PM   #1570
toomany's Avatar
i run one you can't gear with tamiya gears i went to 64 pitch gears with a spur gear adapter part #tb0414 from 3 racing works great. the gears are 78 spur 47 pinon for a fdr of 4.31 it take a little mod work but not much. back in this thread there is some talk about this i think the guy was f1 larry he has pic of what he did with a stock spur gear to do the same thing. the tt01 work ok for this it is a little slow but very tough it can take a beating.i have been running one this whole season.
tc3 vintage trans-am tamiya mini cooper
toomany is offline   Reply With Quote
Old 08-10-2009, 12:28 AM   #1571
mailboxck's Avatar
Hello,
The Carbon Fiber Upper deck was released a long time ago. But when the Type E was released, Tamiya didn't release an updated version for the E.
To answer you, no, it can't be used with the Type E (unless you find a way to mount the steering).
And no, I don't think you can use the sway bar with the new E deck. What I suggest is that you get the suspension arms for the TT01R or TT01D. With those, you can mount the sway bars on the gearbox.
mailboxck is offline   Reply With Quote
Old 08-27-2009, 09:51 AM   #1572
stitchy's Avatar
Can someone tell my why on Tamiya's website:
http://www.tamiyausa.com/articles/fe...article-id=415
it says about the front carbon damper stay:
"In addition, when paired with dampers from the M Chassis Aluminum Damper Set (54000), you can use the new generation of low nose bodies as seen on the TA05 IFS and TB03 chassis."
Question is, for mounting Tamiya's low nose bodies, what's the difference between using the M Chassis Aluminum Damper set and any other dampers? Is it the length or some other reason?
In other words, if you wanted to use the low nose bodies, are you limited to the M Chassis Aluminum dampers?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 08-27-2009, 10:33 AM   #1573
rccardr's Avatar
You can use the super short plastic Mini shocks too- same assembled length. The long regular sedan shocks- TRF or plastic- are just too long to fit.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 08-27-2009, 11:14 AM   #1574
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Your info is flawed. I use the Tamiya 55 spur with an hpi 35 pinion to get a 4.09 gear ratio with my 17.5 brushless. I guess your info would be correct if your still using the stock chasis. I am using the 3racing TT01 chasis.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 08-27-2009, 01:19 PM   #1575
toomany's Avatar
not flawed this work great in the stock tub
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Tags
drift
