Old 11-04-2002, 05:42 PM   #1
Best tires for smooth concrete surface...
What tires have the best grip for a smooth concrete surface? I have a Pro 3 Spec-V and I mostly race on hot weather. My car has plenty of power but the tires that I currently use don't hook-up as i would like.... Any suggestions are welcome.
PRPRO3 is offline   Reply With Quote
Old 11-04-2002, 06:29 PM   #2
If the surface is pretty smooth, you could select softer tires or foam for a start.
rcbanger is offline   Reply With Quote
Old 11-04-2002, 07:19 PM   #3
JohnA's Avatar
For smooth concrete proline caps are the absolute best, they're pretty expensive but last a long time. Try green fronts & yellow rears.
If you can't get hold of any go for rubbers, Sorex work pretty well with a soft/medium insert. I'd avoid foams on concrete.
JohnA is offline   Reply With Quote
Old 11-04-2002, 07:52 PM   #4
popsracer's Avatar
Default Concrete tires
For concrete, Pro-line S3's (any) will give you maximum traction.
I just finished running a race on concrete and the tire to have was Take-Off's 27-CS with a medium T-O insert or the premounted.
The Pro-lines S3's are a little soft so you need to use a firmer insert. HPI 26mm pro molded inserts work good on all of the S3's except the Road Rage tread. For the RR tread you need a flatter insert like a Yokomo 26mm because the rubber is thicker on that one tire and will cause it to be too rounded.
Did this make any sense?
I would try the Take-Off's first, if you can find them. Everyone claims they work great. (I am going to try some this weekend)
Hope all of this helps, good luck racing.
popsracer is offline   Reply With Quote
Can a surface be too smooth? Baedarlboo Georgia Racing 8 04-25-2008 06:44 AM
Tires for Concrete impulsed Nitro On-Road 16 03-13-2007 07:47 PM
Track Surface, what do you like asphalt or concrete? Dr Go Northwest Racers 12 01-01-2005 10:42 PM
concrete tires kh15 Electric On-Road 4 08-16-2004 06:51 AM
Best tires for concrete? Interceptor Electric On-Road 1 07-25-2002 07:30 PM
SEO by vBSEO 3.5.0
