Black Widow
Any other owners on the board? I put mine together this week and the only problem I found was the turnbuckles were to short but I emailed Trinity & they are sending me the correct length ones. I like alot of the features the car has like the new Associated front end, IRS Diff, 4 corner rear pod design (Easy motor changes) & the damper tubes went together well and had a tight clearance that should respond well to different wieght lubes. I also noticed it has a longer wheel base. I'm trying it out this week-end & will post up later.
good to hear. keep us updated
Pictures. A little better than the one's on Trinity's site.
Another.
i am happy with mine. however i am currently working on a conversion kit. there are a few things the car is lacking ( i feel)
stay tuned! :sneaky: |
trinity 1/12th scale
I hear that at cleveland trinity had a new car. Its just like the reflex 12 except the rear pod is like the black widow. No more ae front end back to the dieter front end.
That's just crazy talk........ :weird: |
Knowing Trinity, who would be surprised if that were true?
:lol: |
I had a chance to run the car today and it was better than expected. The longer wheelbase made for some very smooth driving, the car is worth the $$ I spent. I also liked 1 feature especially, the rear pod system not only put the motor flush with the main chassis for a lower center of gravity buy the way it's designed allowed me to get the desired ratio which was a 28 pinion with the 100 spur. It would be no problem to gear up to a 30 if needed with the 100 spur something the CRC, IRS & associated rear pod design will not allow due the the motor gets crammed up against the back of the T-Bar at a certain point with the larger spur gears.
What about larger pinions necessary for some of the quad magnet motors, like a Reedy 19t (flame)? You may potentially run a pinion as large as a 38 on that motor (or larger). Are you running flat can motors, too? I have had a problem getting ride height with any motor that uses a round can in my Reflex. I'm wondering if this issue was addressed with the new car or not?
Tony |
Originally Posted by II Fast
I had a chance to run the car today and it was better than expected. The longer wheelbase made for some very smooth driving, the car is worth the $$ I spent. I also liked 1 feature especially, the rear pod sysem not only put the motor flush with the main chassis for a lower center of gravity buy the way it's designed allowed me to get the desired ratio which was a 28 pinion with the 100 spur. It would be no problem to gear up to a 30 if needed with the 100 spur something the CRC, IRS & associated rear pod design will not allow due the the motor gets crammed up against the back of the T-Bar at a certain point with the larger spur gears.
