Checkpoint 19turn spec mod
#361
Originally Posted by gonzo416
anyone have the part # for the brush spring spacers?
#362
About how much total thickness (range) are you using?
#363
Originally Posted by radio_car_racer
MK-CSS Brush tension adjustment spacer for Check Point motor
#365
Just purchased the motor (actually had it for more than a month) but will be installing it pretty soon & may need some assistance or may need to ask some questions before I run it at my local track.
#367
Originally Posted by bsmooth
Am I supposed to solder a schottky diode to these motors? I'm having intermittant power problems, and just noticed there is no schottky diode on the motor.
Any input is greatly appreciated.
Thanks,
Steve
Thanks,
Steve
#368
Originally Posted by duckman996
Have you tried another motor? It could be the speedo. What Speed Control are you running?
I've checked and reset the speed control. I don't know how else to check this.
I'm to the point where i'm grasping at straws.
Regards,
Steve
#369
..I'm running an LRP quantum 2/ matched IB4200's. I have a team brood money 19t and a stock (money) 19t, both seem to do the same thing: both don't have shottky diodes and both are fresh. I was running an older kisbey 19t w/ schottky diode and matched 3300's that seemed to make more power.
Regards,
Steve
Regards,
Steve
I have never had a problem with my CP 19T motors - these things are bullet-proof.
#370
I had the same problem with my QC2... for some reason the speedo was was cutting in-and-out. You can try a shottky - the cheapest route. If that doesn't fix it (which I doubt it will), try lightly tapping on your speedo and seeing if it makes a difference. You could have something loose inside of it causing the problems (like mine was). I replaced the speedo and all problems when away. BUT before all that, I would check to make sure the lead running from the speedo to the receiver is not damaged (broken or crimped wires). Make sure it is plugged into the receiver.
#372
Re: tuning tricks!
Originally Posted by SpidarX
I'm running a checkpoint 19t with infinity brushes, and I'm thinking of installing the silver/hard springs on it. My concern, however, is whether or not the harder brush spring will cause the motor to run hotter? Any ideas? thanks.
The only issue is it will take at least two runs on the track for the brushes to fully seat. Breaking in the motor on the bench just won't do it! By the third run the motor will be ballistic!
