NEW XRAY T2
#1186
Originally Posted by MasterBlaster
I've never had a car in which I had to tape in the batteries. What kind of tape do you use? Is this really necessary, it sounds sort of archaic.
* Cut a new strip that is slightly longer than needed to go around the top of the battery twice and under the chassis once. Hold it *stuck* to your right index finger
* With your left hand, pickup the car and use your belly (in my case oh the joys of being fed well by the wife ) or waistline/belt/top of pants to support the front bumper and support the rear bumper, with tires hanging off, with the counter/table edge. Make sure you don't move away and drop the $400+ work-of-art!
* Thread one end up from the bottom and through the rearward slot. Pull it through and stick the end onto the rear shock tower.
* While keeping the tape straight, stick it to the bottom of ONLYthe first three slot fillers in order to keep enough play for you to thread the rest through the front slot without sticking it together and starting over.
* Thread the other end up from the bottom and through the forward slot. Pull it through and stick the end onto the front shock tower.
* After installing the pack, cut the ends appropriately so that both ends overlap each other almost the entire length of the top of the pack.
Voila!
#1187
I hate the tape only because it ruins the labels of my matched cells and yes inconvenient also
#1188
#1192
i cover the labels with clear book covering film. Just cut into strips and wrapped over the label. Stops the, getting wet of you run in the rain over here too.
#1193
Extra shrink wrap make them larger and then they struggle to fit neatly in the slots, it also insulates them more so they will run hotter which inceases their internal resistance. I just cover the label
#1195
#1196
Originally Posted by L.Fairtrace
Shrink your cells and you wont have that problem and it will protect them better. I shorted out a cell when I didnt use wrap becasue I got tboned and it slid my battery a little and cut the single wrap on the cell and caused a nuclear reaction in my car.
#1197
i cover the labels with clear book covering film. ...
BTW bench racing I never do this I just like when my stuff is nice and neat
#1198
You can buy it online at Speedtechrc.com.
Here is the link:
http://www.speedtechrc.com/store/ebp...id=400&id=5195
Here is the link:
#1199
Here is the link:
Here is the link:
#1200
