NEW XRAY T2
#5386
Originally Posted by teamgp
Per the last line, you will have to contact your LHS/supplier and have them contact their distributor for the latest XRAY price list. Then they should be able to order them.
#5387
Originally Posted by Joep
Are these brackets the same ones belonging to the Adjustable Upper Deck T1FK'05 - 2.5mm Graphite ?
#5388
Originally Posted by AChupp2
I was wondering if an online shop may have them and I could get one faster that way. My LHS usually doesn't carry Xray products so it would be a hassle going through the LHS.
#5389
Originally Posted by a2theb
Art - Got my plate over the weekend. It's awesome. First use I already found my chassis tweaked a bit. Thanks!
How much narrower is the revised upper deck? I'm not sure which one I have. I have a 9402 mounted with I believe 3mm shims and the arm just barely grazes the deck. I was planning on filing that area down a bit to give more clearance. The 9402 already sticks out quite a bit. I think I may try moving the link to the other side of the horn as well.
Awesome!! I am glad to hear the plate made a difference for you.
Thanks for the feedback.
#5390
Teamgp...
When's Xray going to offer diff halfs separate? I just ruined another and I out for a month. I can't take it anymore! Please tell me that Xray will offer a plastic diffs at a much lower cost. I want to be able to buy what I need and not be forced to spend $60 every time I need one diff half.
#5392
#5393
Hi all, I'm quite new on the forum. Personnaly, I'm working with a friend on delrin diff outdrives. With them, I will use Tamiya aluminium bones because for me, the issue with Xray bones is the price and the blades. So good bye the blades because I've broken two Xray outdrives because of wear on them loosing blade durinf a run!!
I'm currently using a front spool in delrin with steel outdrives and with Tamiya 46mm steel bones. After a complete month of use with modified motors, no wear on the outdrives! The next evolution on the spool is to make it in aluminium with delrin outdrives. The weght of these spool are lighter comparing to the multidiff:
- multidiff: 15g
- delrin spool with steel outdrives: 14g
- aluminium spool with delrin outdrives: 8g
Here is a pic of the last spool. Keep you informed about the diff outdrives. Conception and fabrication are made by my friend and sponsor, he's doing that on his free time!!
- multidiff: 15g
#5394
Looks well made, good job. I dont see any mounting holes, how do you attach the belt pully to the spool?
#5395
this one isn't finished, of course the mounting holes will be on it!!
#5397
The FK05 dogbones are $32 a pair, the T2 dogbone is $21/piece that's just a ridiculous rip-off. They are basically the same...
#5398
Yes that's why I use Tamiya bones with Xray axle. Both are compatible, no problem with that!
#5400
There are different length! I use 46mm now but with the first bersion of the spool I was using 42mm bones.
I will try to post pictures of my car later if you want
