NEW XRAY T2
#5221
Hey guys,
we just started a rubber tire class at our track and I just had a quick question.
What spring rates is everyone using for :
Rubber tire / Carpet ?
I tried the,
17.5lb (white) in the front
15lb (blue/green) in the rear
Car felt very stable, but felt like it was scrubbing alot of speed in the corners. I know I'm used to foams. is this normal ?
thanks !
I tried the,
thanks !
#5222
Originally Posted by SpeedDesignz
Hey guys,
#5223
Originally Posted by Nexus Racing
I think that the stock silver and gold springs are the most popular for rubber tires on carpet...you should give them a try if you haven't already.
Thats what Flack was running at Cyruls when I saw him racing his T2 rubber tire carpet and his car was fast and hooked up.
#5224
Originally Posted by Art Jensen
Plates are in guys. This batch is over half gone already. If anyone would like one, let me know. Here are a few pics of the big dogs' plates.
#5225
hi all! this may be a question already asked but would the diff outdrives for the fk05 work with the T2? need to replace the ones on my T2 and the only ones available locally are the ones for the fk05. i know they arent the milled-out/lightened ones but as long as they will work i can live with those for the time being.
oh, and another question ... have any of you had the rear rims rub against the rear shock ends when mounting the shocks in the outter hole on the rear a-arm? mine rubs bad and have gone through a couple of shock ends already. was just wondering if this is somthing other have experienced. i've used much more, yokomo and speedmind rims and they all rub enuff to eat through the shock ends till they snap. dont wanna use the inner holes on the a-arms coz they do change the handling of my significantly and i really like how my ride is now set-up wise. any thoughts?
#5226
1) 05 outdrive work with T2 diff they are the same basically
2) you may want to try to put a shim between the hex hub and the wheel and/or use wider hex hub. However this will also change the handling of the car a little.
Theoretically if you move the bottom of the shock in the inner hole and do the same with the upper mount keeping the shock angle then put on a harder spring you should get te same handling
#5230
Trader Rating: 32 (100%+)
Originally Posted by Rick Worth
Any one know if Pdub is around? I ordered some RW spur gears over 2 weeks ago & haven't recieved them yet. Also never returned my e-mail. Thanks. R.W.
#5231
#5232
Originally Posted by ROBORAT
cvt01: great! good to hear the outdrives are a direct fit. thanks on the tips, i mite go with shimming at the hex instead. tried doing the inner arm and inner hole on the shock tower option but it just didnt seem to feel right. thanks again!
#5233
How's it going Kevin? Will you guys be practicing on Fridays or Saturdays next month at IRP? We lost our local track so I need a place to run a couple of times before Vegas. You guys all going again? Haven't touched rc since the Carpet Nats since karting started.
[email protected]
[email protected]
#5234
Rick you got an email.....
#5235
composite spool housing? http://www.rcinfos.com/2006/2006_07_...worlds_344.jpg
