NEW XRAY T2
#5026
Originally Posted by Alex C
You are so correct Rick........Jason from BMI Really know's how to make a quality chassis!!
His work is impeccable!!
Best Regards,
Alex
Best Regards,
Alex
Question....
How come the top deck is counter sunk? I thought the floating idea was better. Or is that the issue with tweaking?
#5028
Trader Rating: 50 (100%+)
Originally Posted by Mongo
Question....
During a hard hit or say a slight tap on the board sideways......with the Multiflex Chassis you had a tendency to tweak the car!!
Now with the counter sunk top deck's, and front/rear shock towers you have a less degree of tweaking the car.
Also one key thing to remember is the BMI Chassis compared to the Xray chassis is the type of carbon fiber that is used on both chassis.
I know Bmi's carbon fiber Chassis is made of alternating fiber layers that are layered in a 0 deg to a 90 deg, and to a 45 deg weave.....which makes the chassis very rigid and less prone to tweaking the car.
Feel free to pm if you have any other questions........also feel free to visit BMI's website @ www.bmiracing.com !!
Best Regards,
Alex
#5029
Mongo,
Best Regards,
Alex
Best Regards,
Alex
"• XRAY Anti-Tweak Smart Design - chassis and top deck are designed to prevent the car from becoming tweaked during a crash" from teamxray.com
#5030
Read his list o sponsors...*BMI*
#5031
Originally Posted by Nexus
So basically as a sponsored driver you are saying the stock T2 chassis basically tweaks pretty easy
Thanks for the BIG WOODEN SPOON ........it is just my humble opinion that while running the stock xray chassis on asphalt rubber tire may be the better of the two, although while running on a foam carpet track the BMI Carpet Version Chassis is far much better of a chassis in the matter of tweak!!
Best Regards Anthony,
Alex
#5032
#5033
Feel free to give the BMI chassis a try.......than make your own opinion!!
Nexus,
Alex
Nexus,
Alex
Plus I still have a Big wooden fork left....all fili's have a big wooden spoon and fork in their kitchens.
#5036
Originally Posted by THE DARKSIDE
Does anybody know if the T2 kit standard outdrives can be purchased by themselves? All that I've seen are the ones for the one-way and multi diffs. I really don't want to purcahse an additional complete diff everytime that I bend/break an outdrive.
Any ways, this was the closest I found.
305010 Alu Diff Long Output Shaft Hard Coated
305020 Alu Diff Short Output Shaft Hard Coated
No idea if they are still available.
#5037
Originally Posted by Anthony.L
My gawd, how hard are you hitting the boards? I've never broke a Xray steel diff. I see the guys with alum outdrives do it all the time.
#5038
not to start any conflict but a few of the xray drivers have changed to my chassis kit for the added rigidty,performance,and because it doesnt tweak.
i see what xray was doing and commend them for doing something different but it does tweak pretty easy.it is also difficult to put together and have everything be straight.i know alot of people are going to disagree but if you go to extremes like myself with assembly and inspection,you will see this also.it is an excelent car and does run great with the stock chassis on it.i just tried to cure a few of the problems that i found and added some features that have seemed to help performance.
#5040
