NEW XRAY T2
#4906
Hello everyone, I read in some Setups that they cut the front or the rear arms. Can you please explain or show us where or what exactly you cut??
thanks
Harris
thanks
Harris
#4907
thanks
Harris
thanks
Harris
#4908
Originally Posted by Joep
please place a link one of these setups so we can see what you mean?
http://www.teamxray.com/xforum/xform...D=680&setup=t2
Please see on the comments
thanks
#4909
#4910
thanks Joep, this is what i thought also....but i wasnt sure...
#4911
#4914
Originally Posted by protc3
how much did they cut out on the arms.i was working with jared scott at the track a while back on getting the car to flex.we tried removing the webbing in the arms and they were still pretty stiff.those little buggers are stout.
On the front, remove the only rib that is on the arm (but be careful of the roll bar mount, some drivers have only cut half of the rib away because they were worried about hitting the roll bar mount). Then remove the thin rib thats in front of the roll bar mount.
I couldn't notice much flex with them either, you can notice a lot more flex when you have them on the car and you try to move the caster block. But I was told I needed to work out more if I couldn't feel it
Hope this helps, its quite hard to describe.
Jonny
#4915
Jason - You guys over at BMI have the spools ready to ship?
#4917
How long is everyones rear blade's lasting. Actually more for anyone running mod. I have three races on the car and both rear blades wore down to the pins. Wierd actually only one half of the blade, on each side.
I didn't check those until now during my rebuild. On my other car/brand, the rears lasted for 4 to 6 months. Just wondering if it is normal on this car. My diff is medium-to-medium/tight.
#4919
Yep. its the rears that wore out like that. Wierd I would think. I just wanted some feedback from those that have been running it for a while now. I go through front blades in about 2 runs with a spool. Which is normal for me.
