NEW XRAY T2
#4591
I doooooooooooooooooooooooooo but you can't have it......... you know I'm playin homie...
Peter Robinson help him out give him a good starting point.. come on
#4592
Ackerman
Has anybody tried the different ackerman(sp?) settings? havnt had time to play with them myself yet, just curious as to what changes you noticed.
Thanks in advance
Thanks in advance
#4593
has anybody added any weight to the car to help make it handle???
do the T1 chasis weights fit???
#4595
Originally Posted by m8commando
Reedy Race 2006 setup for Xray T2: Does anybody have any input on good setup with RP30's.
sway bars maybe? looking for input.
#4597
#4598
Originally Posted by racenut123
Anyone have a good starting point for a oneway on asphalt??
Hope that helps.
Drew.
#4599
Originally Posted by Drewdc90
What do you mean exactly?, You don't need to add weight to make the car handle better. You should just add weight so it is on the limit and use car setup to banlance the handling.
you cannot just use the car setup to balance the car. the components installed in the car makes the car's weight different from left to right. use your balancing tool and you will find out
#4601
the 4 scale will do your spring preloads more like a tweak board. the balancing tool is to balance the weight of the car from left to right. the first time i did it, i was surprised to see how heavy the left side of the car was. now i have all kinds of weights on the right side to compensate. it's worth it though.
#4602
also i forgot to mention that it's always worth it to check the balance again when you change to different mah battery or different wound motor. the weight difference really upsets the car (i.e. 3300 to 4200 is about 3oz difference as i recall it)
#4603
#4604
#4605
aluminum shock bodies
i do hope that X-Ray will come up will cool aluminum shock bodies for the T-2 not that i do not like the plastic bodies but since they came up with some cool aluminum stuffs with this car might as well include the shock bodies too
