NEW XRAY T2
#3197
Originally Posted by HarshGuy
hehe
....tracks been awesome ...I'll be there this Saturday then 03/05 for practice ...then the Nats.
#3198
I think there is a race on 3/4 and practice 3/5.. no racing on the 2/25
I think the schedule is up to date with this..
http://www.stocktonrcraceway.com/
#3199
#3200
Originally Posted by Michael Barch
Alright thanks, Yeah like two of my shocks are fine, and two of them I push up on them and I hear squeeking noise so Im going to re-build those ones.
One last question about the belt. How tight/loose should it be? Right now it seems a bit on the tigheter side (Front all the way up) (Rear one back from standard).
Should I just put both at standard, or what should I do?
About the Diff's, I will do that. Thanks.
One note- I told you to set your diffs that way not just for your benefit, but for other new Xray owners. The purpose of doing it that way is to avoid overtightening the diffs before being fully broken-in. A seasoned racer can set the diffs on the bench and get them really close, only having to recheck them once or twice, but a new racer should "sneak up" on the correct diff setting until he/she is more familiar with it. Xray diffs are extremely smooth and stay that way longer than any other car I've ever owned, but if you don't break them in correctly they wil never be as smooth as they can be.
#3201
Thanks, I just cannot seem to get how to do this shock thing. It is just getting me frustrated so Im going to get some help from my Shop.
Everything else is great now, I set the belts good and everything, about to go pick up a new servo case I need (I had to cut the part of the old one to fit my TC4...around the shaft).
Thanks for all the help, I can't race it tonight though, I still got alot of setup to do and all that good stuff!
-Mike
-Mike
#3203
Aren't X-ray shocks suppose to be great? and have adjustable damping feature? Why I am hearing a lot of people are using TRF shocks instead?
#3204
Team EAM
Once you get the Xray shocks built right they last forever and are as smooth as any others out there.....You just have to learn how to do them right.
Most guys put the Tamiya's on because they are to lazy to learn how to build Xray's right or dont want to take the time or are just more comfortable with them.
EA
EA
#3205
I just build the shock by first using a air-remover like the one above that Hara is holding, then undo the bottom cap and push the shaft in about 2-3mm which releases a bit of oil and twist the cap back on. This gives me a full re-bound which i like, i do this with the piston holes all open, then a change the piston hole to one open on the front and 3 open on the back, this all takes about 15 minutes. I love the shocks.
#3206
I ran Tamiya shocks until I bought my 05... I find the XRay shocks very easy to build and seem to last forever with out attention. I just check them from time to time and they still don't need a rebuild. My Tamiya shocks wore out the bushings that the shafts ride on way too often and more than once the lower part unscrewed and the fluid ran out
#3208
I think Michael might be talking about the bottom cap of the shock body. You need to use the Hudy tool to compress it on. Also the X-Ray plastic is pretty durable. It was suggested to me to use a screw at first for the ball ends. I threaded it with a screw a few times using some bar soap (natural lubricant), and it helped me out alot. Hope this might help ?
Here's a link for the tool:
http://www.speedtechrc.com/store/ebp...id=435&id=4902
#3209
My bad! I wasn't reading the instructions careful enough.I was unscrewing the top of the shock, not the bottom.I'm not used to doing that.As soon as I loosened the bottom and waited about ten minutes I was unable to bleed the shock, thanks for the help guys. I gotta agree with the Tamiya shock post, they are very easy to build.
