NEW XRAY T2
#3107
Originally Posted by Anthony.L
I was thinking about posting the exact same question on the XRAY forums. I would also like to hear why they made that choice. I'm sure for a reason.
#3108
Originally Posted by HRCRACER123
I saw this pic of someones car on Pdubs websight. What top deck is it? and it looks like it is countersunk. I could be wrong though...http://www.pdubracing.com/Snowbird_national%20032.jpg
Also who has tried the CRC top deck? is it countersunk? Does it help with the tweak issue? Thanks..
Dom
#3110
Either way, it's WAY stiffer then my kit top deck. Gripping the shock towers and trying to "twist" the chassis is much harder now.
#3111
does anyone know if the 05 sway bars fit the T2 front? rear?
#3112
That is Paul Lemieux's winning car. Paulie had broken his T2 practicing at home and switched to a home built 3mm chassis & top deck. The car worked very well and didn't want to make any changes.
The rest of the Xray team used a new 3mm chassis & top deck along with a modified front arm moving the shock in between the stock holes.
Originally Posted by litespeed-dom
Looks like the same top deck on Ralph's car at Novak. Notice the extended front standoffs area. I'd asked Team Pickles to look into manufacturing their top deck in this fashion.
Dom
Dom
#3113
Originally Posted by rmargiotta
Where's teamgp at, I only looked at the top 50 so I may have missed him...
I must say that I learned A LOT this past week.
* The true meaning of 'high' grip
* The true meaning of no sleep
* Competitiveness almost beyond reason
* How to make the car do a triple lutz into the net
* How to squander almost two laps and possibly a D main start with only 3 laps to go in a 19t qualifier (nerves were a little tense with my wife, mom, sister and son watching)
* How to drive the T2 with rear wheel drive only (front belt flipped) and serious over-steer
* Very frequent changes in track conditions/grip between runs
* How to study the pro's for fast line tips
Unfortunately I had to give up my best chance at some hardware with the 19t F main starting during church time.
All in all, it was a good experience. Now I need a vacation and some rest!
#3114
Originally Posted by howard hudson
now come on dont hate. At least he is there and not in front of a computer wishing we are there
guy hood
10th stock G main
3rd sport19t F main
guy hood
10th stock G main
3rd sport19t F main
#3115
I got one of the countersunk CRC ones along with several other racers.
It caused tny chassis to bow so much the car rocked front to back.
All had similar problems.
We swapped out for the REVISED one and had no problems.
One issue I have been noticing and is something work cheking regularaly is that the screws holding the eccentrics in for the roll centre will bend, this will cause the car to tweak.
All I do is losen them out a couple of turns and see if they are OK.
#3116
Exactly, here's more details and my situation exactly. I'm in need of rear hubs, stock ones are 1 degree outboard toe. Spacers inboard give it another 2 degrees for 3 degrees total. I will have new hubs here shortly, but they are 2 degress of outboard toe. I'm going to change the inboard spacers to 1 degree to still maintain the same overall rear toe-in. The question is, will this change the handling of my car to any extent that is noticable on the track?
* Rear arms will be 'swept' forward more
* Wheelbase will be shortened
* Rear track width will be increased
These changes can affect the overall car's handling in a lot of ways, but only actual track time will show the results.
Team drivers have found that using at least 1d of out-board toe-in will produce a more stable rear end and faster corner speeds.
#3117
Ok. This is a two part post. The first is NOT an apology in anyway, but a statement of realization. I can see that this apparently needs to be taken up in a public LOCAL area, fewer here are interested than i anticipated. No apology because i truly feel what i said... my words are not to be re-chewed, i thought about what i said before it was sent. For those of you who feel the need to flex your internet muscles about "whining", you are lucky i do not know you personally. Although... i am sure i would not have to look far to find something of "interest" about you... i will digress.
Rob Phillips, no worries, its squashed in here... ill tend to the issue at the track.
The second part of my post is a general question for those who prepped their chassis with CA. Did everyone/anyone get inbetween the slots in the top plate with CA, or did the outer edges ONLY receive the CA sealing? Im debating if i should worry about it or not. Does anyone know a way to get light scratches out of the surface of the CF plate and restore the shine? When i say scratch i mean a scratch that goes into the surface of the shine and no further. (Like, an idiotic grazing of a wrench on the CF while removing a screw that popped out of the hole and left a mark on the CF) Yes... i like a purty car.
- Dave
- Dave
#3118
#3119
Originally Posted by Ill Factor
Tamiya 6 or 5 mm locking hexes, I believe Xray has some comming out soon in 5mm
#3120
I just did the edges of the top plate. I was thinking about running the q-tip down the interior slots but figured it would just make a mess.
