Old 11-28-2005, 11:45 AM   #1
Default Spool vs. One way
I just got an HPI Pro 4 Hara and it included both a spool and a one way (no front ball diff though). On my previous cars, I only used a front ball diff. I usually race on asphalt with low to medium traction (though I may race a few times on carpet over the winter).
Sorry for asking something that has likely been discussed previously. Can someone post a brief summary of when or why to use the spool versus the one way? Also, are there any circumstances where a ball diff would be the best choice?
iblumberg is offline   Reply With Quote
Old 11-28-2005, 12:48 PM   #2
Superkarter's Avatar
You will need different setups for both.
The one-way generates a lot of steering and corner speed but you have no front brakes. Use the one-way on tracks that don't require a lot of hard braking.
The spool reduces steering at the front end with the same setup as the front wheels can't turn independently of each other but a spool carries lots of corner speed and is far superior to a ball diff in braking. The spool is probably more useful on tight tracks with lots of braking.
Superkarter is offline   Reply With Quote
TF-5 Spool VoneSkip Australia Wanted to Buy 0 04-22-2007 02:45 AM
Spool set up JL Electric On-Road 11 04-02-2006 11:49 PM
New Alm Spool for HPI Pro 4 topgluer Electric On-Road 4 09-08-2005 12:00 AM
Spool propain Nitro On-Road 9 03-14-2005 07:33 AM
what's a spool? rcnewb2004 Electric On-Road 21 12-05-2004 09:54 AM
SEO by vBSEO 3.5.0
