Old 11-24-2005, 03:54 AM   #16
sosidge's Avatar
Up to now I have been marking my tyres and always using them at the same corner. This makes the car very consistent.
The problem I have started to have at a new track I'm visiting is heavy front tyre wear which is effectively rendering the whole set useless after 1 race meeting (20mm minipins on a slippy floor).
So, I'm going to start rotating tyres to see if I can get a second or even third good week out of a set (I don't expect more than 3 meetings from a set of narrow minipins before they become completely useless).
I will be rotating in an X after every run. That way the tyres don't have much chance of getting mismatched as they will only have five minutes wear on them in each position.
I did try rotating the current set, but after approximately 8 runs on them the difference between front and rear was SO great that a car with terminal understeer became completely undriveable with massive oversteer.
Old 11-24-2005, 01:26 PM   #17
I rotate mine before each meeting (club) and I go Front-Left to Rear-right & Front-right o Rear left. This does not seem to affect the car compared to no rotation but helps to get a more even wear and they last longer than not rotating.
Steve B is offline   Reply With Quote
Old 11-24-2005, 03:45 PM   #18
pheyhoe's Avatar
R/C Tech Charter Subscriber
I swop my 20mm mini pins front to rear after each club meeting 4, 5 minute races. (running LRP Top Grip Carpet additive, so even when the tyres are nearly bald i get plenty of grip.)
My foams i run very little camber and try and keep them on the same corner. I found that swopping foams around really upsets the handleing/balance of the car until 2+ runs later when they have bedded in.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 11-24-2005, 03:57 PM   #19
Jack Smash's Avatar
Trader Rating: 28 (100%+)
I only swap rubber tires from front to rear, never from side to side. Something happens to a tire once its run in one direction and then reversed and run the other way. When you reverse it, it seems to have less traction. This came straight from a tire distributor.
Jack Smash is offline   Reply With Quote
park 480 outrunner backwards rotation sirelboe RC Flight 1 03-17-2008 01:40 PM
Tyre Truer AndyT Australia For Sale/Trade 3 11-08-2007 01:05 AM
Hudy Auto Tyre Truer and Trinity Tyre Warmers Rody Australia For Sale/Trade 4 04-18-2007 08:35 PM
Reversing the rotation on a brushless motor smac Electric Off-Road 7 04-06-2007 05:10 AM
Tyre truer griffo Australia Wanted to Buy 0 04-09-2006 01:36 AM
SEO by vBSEO 3.5.0
