Tamiya Direct Drive Touring Car
#286
Originally Posted by heavy
I agree very different from a AWD - can you change the throttle profile in your transmitter or ESC to compensate.
may I ask a few questions
What bodyshell did you use?
What motor and did you use the standard gearing?
What surface were you on?
#287
Originally Posted by scott_g
I have only one question:
Who will be the first to bolt in a Novak GTB/4.5 and take it for a blast?
Can I say 'Got dragster'...
#289
Originally Posted by Burlap
You'll have to find a way to get the power cleanly to the ground, even with a 23T it is dicey.
I'll be waiting for my local tamiya races to officiate this class before buying a F103GT. Probably next year would be the year.
#290
Hi Guys,
Just want to post that we now have spares in stock for the F103GT
Tamiya F103GT Parts
I sure hope Tamiya makes this a TCS class (maybe it can be the new GT-3 class)
Steve Wang
Tamiya F103GT Parts
Steve Wang
#291
Hey guys, happy to report that I have garnered positive results at Tamiya track yesterday.
Fred M. of Tamiya test drove my set-up and he was well please with how the car performed. Getting driving tips from Fred with this car was a big plus as well. TY
Rumors has it as well that it will make it as an invitational class at TCS events.
Check the VIDEO here for a short look of the cars handling.
#292
That car looks smooth.
#293
Well, don't Bogart the secrets dude, what's the setup on the F103? Are you running kit parts in it, or are there some hop ups?
Reverse spacer up front for more ride height/Black hard springs
Used #2 adjusters on the rear
0º toe up front
Blue tamiya springs with 40w oil
64 pitch 104/22
Hopups
F1 Rear Diffuser
Carbon Rear Shaft
and Tamiya Plastic Shocks
#294
I'm also happy to say that I finally got the kit dialed. I was disappointed last time I ran it always oversteering and spinning out.
Now my setup is front 26mm kit included tires,wheels,insert with add'l 0.05mm red hex spacer and 24mm 32r with medium inserts with add'l 1mm silver hex spacer. I loosened the ball dif another 1/4 turn from the manual and placed the T4 spacer above the steering knuckles.
Ran a 23 turn tamiya with 2400 tamiya stick pack and runtime was over 20 mins. Motor was really hot so I'll be getting that f103gt alum motormount. I also used a tamiya 350z calsonic body.
I'm impressed! I launched the thing thru corners trying to spin it out but it wouldn't! Feels like a super light touringcar. The people there watching were amazed to see a 1/10 2wd touring running with awd. My kit was box stock after all. Finally a low budget K.I.S.S. rc for $85.
I just dont like the gearing. Still too low for a 23 turn. I can't fit anything bigger than 14T with that 0.6 module. I think 4-4.5 for a 23 turn would better. I'm switching to 17 turn actopower for the stock gearing next time.
If I switch to 3600-4200 nimh stick packs, whats the best way to maintain a stick pack like that?
#295
Take off 27's (Pre mounted)
0º toe up front
64 pitch 104/22
Hopups
F1 Rear Diffuser
Carbon Rear Shaft
0º toe up front
64 pitch 104/22
Hopups
F1 Rear Diffuser
Carbon Rear Shaft
The toe seems right, and so does the oil. Cool, thanks
#296
0º toe up front
64 pitch 104/22
Hopups
F1 Rear Diffuser
Carbon Rear Shaft
0º toe up front
64 pitch 104/22
Hopups
F1 Rear Diffuser
Carbon Rear Shaft
#297
#299
who's driving in the video? Fred said there'll be a TCS exhibition class for the Aliso Viejo regional
#300
