Spice BD7 2015 FWD conversion kit: >
Like Tree1Likes
Old 05-29-2016, 08:43 PM
  #16
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
question
Why this conversion kit only for BD7 2015 ,why not 2014 or 2013?
OVA is offline
Old 05-30-2016, 12:35 PM
  #17
Trader Rating: 6 (88%+)
I don't know I never buy yokomo car except this one... maybe the bulkhead hole position/mesurment is different
Quinny45 is offline
Old 05-30-2016, 01:27 PM
  #18
Cadman1981's Avatar
http://www.redrc.net/2014/09/yokomo-...uring-car-kit/
Which parts are needed from the Yokomo?
Cadman1981 is offline
Old 05-30-2016, 05:00 PM
  #19
all parts except the frame , the upper front bulkhead and the front shock tower...
at the start I looked for the BD7 RS v3 but the car base is from the bd7 2014
Quinny45 is offline
Old 06-05-2016, 07:26 AM
  #20
after a full day of practice yesterday the car still feel awesome !
my laptime is a little bit faster than my fiend with a MTS FF
I switch Yokomo shock for xray 2016
I run xray 2.5 front and 2.3 rear I ordered xray 2.9 and pregressive version ( 2.5 2.8 - 2.3 2.6 ) for testing
and the frame is not so stiff as well I screw the steering brace to top deck for add stiffness
the car is reatively fast I push the back of my friend with awesomatix A800 AH with the FF both 21.5
the car is very stable and flow very well
weight with celica body = 1212gr ( with yokomo spool )
Quinny45 is offline
Old 06-05-2016, 07:45 PM
  #21
OVA
OVA's Avatar
what are you saying is .The BD7 RS V3 kit is all I need with the conversion FF kit to complete my Front wheel car?
OVA is offline
Old 06-06-2016, 02:11 AM
  #22
no ! because the BD7 RS V3 is like the BD7 2014 ! and you need the 2015 !
Quinny45 is offline
Old 06-06-2016, 04:13 AM
  #23
Chrissy C's Avatar
Ova, maybe ask on the main Yokomo thread what the differences in '14 and '15 bulkheads were. I know that the '15 has the 'X' brace which connects the left and right bulkhead, but aside from that, I thought they were the same...maybe not!
Chrissy C is offline
Old 06-06-2016, 04:29 AM
  #24
DirkW's Avatar
At least the way the shocktowers are mounted on the bulkheads is different between the '14 and the '15.
DirkW is offline
Old 06-06-2016, 04:44 AM
  #25
Chrissy C's Avatar
Ah, good point, but the conversion just uses the lower portion of the bulkhead - well, at the front anyway, so you would certainly need the '15 bulkheads for the rear as the conversion comes with a rear shock tower.
Old 06-06-2016, 12:35 PM
  #26
I ask the question on spice racing facebook page
Quinny45 is offline
Old 06-06-2016, 01:48 PM
  #27
Me and my friends we talk a lot about battery. We race in the usgt class and we have a lot of question about the weight vs. battery power . For now we have shorty pack from fantom 3900 100c 150g. The battery is good but fade quick, after 2-3 min of run time the car feel more soft less punch and lap time drop alot. I ordered another shorty pack from hobbyking 4600 mah graphene battery for test if this shorty keep the power longer or not. If the result is negativ I will probably test LCG pack from fantom racing 2mm lower than std pack and 31g less weight than reg pack with the same mah ( 6000mah )
Quinny45 is offline
Old 06-07-2016, 01:37 AM
  #28
Chrissy C's Avatar
Quinny, I'd expect the 3900mah battery to fade after that kind of time, the 4600mah should be much better. I run the Nanotech Ultimate 4600mah and find it fine. Reedy has a new 5200mah out in shorty form, and there is a TC car (Gizmo) based around the use of shorty cells. The Gizmo has been competitive at the ETS (blinky class), so shorty technology is pretty much at that point where they can be used with little disadvantage in power. Good luck with the tests.
Old 06-12-2016, 01:45 PM
  #29
I do some test yesterday with my friend Pat shorty turnigy graphene 4600 shorty vs orca 6200 std pack. I run the sorty in my spice and pat run his orca in MTS FF same FDR and we do the same lap time ! at the end he was faster than me ! the difference between these two battery at the start is very small ! this is why i dont know if the lightweight has really a advantage vs bigger gaz thank ! next test = 21,5 & 13.5 with IP 7800 100c battery !
Quinny45 is offline
Old 07-17-2016, 05:52 PM
  #30
OVA
OVA's Avatar
Default set up??
well
I am just wondering if anyone has the asphalt set up?
OVA is offline
