Old 11-14-2016, 07:06 PM   #61
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Originally Posted by Quinny45 View Post
woooohoooo !! I received the secret parts and the parts fit bolt-on !!!
I give a small hint fot the parts.... LS1
Fit probably on all yokomo/Tamiya
Xray Steering rack fit on yokomo?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 11-14-2016, 07:26 PM   #62
Trader Rating: 4 (83%+)
nop ! not from Xray
Xray T4 2017
Yokomo BD7 2015 Spice FWD
VBC FF17 FWD
VBC FXM F-1
Roche evo 2017 F-1
Quinny45 is offline   Reply With Quote
Old 11-14-2016, 11:55 PM   #63
vlad_sa's Avatar
Ah Yokomo wishbones etc pp and linear steering from Awesomatix!
I also run the complete Yokomo suspension on my Raceberry EVO 5.
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
vlad_sa is offline   Reply With Quote
Old 11-14-2016, 11:56 PM   #64
vlad_sa's Avatar
But looks really good, I wouldn't mind trying the Aluminum chassis even tho I'm not a big fan of them.
Old 11-15-2016, 02:52 AM   #65
Chrissy C's Avatar
Good work Quinny!
So is the LS1 a direct fit? no mods needed?
What does the LS1 do differently/better to a normal steering set up?
Chrissy C is offline   Reply With Quote
Old 11-15-2016, 01:47 PM   #66
Originally Posted by Chrissy C View Post
Good work Quinny!
direct fit ! the only problem the steering bridge need some modification ( grinding or sanding ) to fit again under the topdeck and the ackerman is a bit different because the distance between the 2 balls on the rack is very different you need reduce the leight of the steering rods alot if you don't want 5 deg of toe in !!
Xray T4 2017
VBC FF17 FWD
VBC FXM F-1
Roche evo 2017 F-1
Old 11-15-2016, 01:49 PM   #67
Originally Posted by bigdogswhitebus View Post
Rcmart the go?
fot the Awesomatix LS1 system I ordered via awesomatix usa I dont know if rcmarket have awesomatix parts
Xray T4 2017
VBC FF17 FWD
VBC FXM F-1
Roche evo 2017 F-1
Old 11-15-2016, 08:09 PM   #68
Trader Rating: 14 (100%+)
Default Looking for a kit
I am looking to purchase a conversion kit, but it looks like rcmart is out of stock...
Does anyone know of any other sites that sell these kits?
Or does anyone have an extra and or used kit they would like to sell?
puhrot is offline   Reply With Quote
Old 11-15-2016, 08:22 PM   #69
http://banzaihobby.com/rc/rc-car-par...okomo-bd7-2015
Xray T4 2017
VBC FF17 FWD
VBC FXM F-1
Roche evo 2017 F-1
Old 11-28-2016, 09:35 AM   #70
What is different with the rear shock tower in the Spice conversion?
Is it possible to run the optional Yokomo short shocks with this kit using the Yokomo rear shock tower?
Old 11-28-2016, 12:05 PM   #71
OVA
OVA's Avatar
Spice conversion doesnt come with rear shock tower...
Old 11-28-2016, 12:11 PM   #72
Sorry, I meant the front shock tower.
Is it possible to make the yokomo front tower work to run the short shocks?
Old 11-28-2016, 03:29 PM   #73
OVA
OVA's Avatar
anything is possible if you have the tool to remake the shock tower carbon graphite for short shock..
stock BD7 front shock tower will not fit on spice bulkhead
Old 11-28-2016, 03:36 PM   #74
Thank you for the constructive and valuable input...
Old 11-30-2016, 02:35 PM   #75
on mine I run xray short shock modified with a tamiya ballcup to reach 65mm with SMJ short spring
with my friend we work on shock tower and topdeck desing soon
Xray T4 2017
VBC FF17 FWD
VBC FXM F-1
Roche evo 2017 F-1
