Spice BD7 2015 FWD conversion kit:
#31
I do some test yesterday with my friend Pat shorty turnigy graphene 4600 shorty vs orca 6200 std pack. I run the sorty in my spice and pat run his orca in MTS FF same FDR and we do the same lap time ! at the end he was faster than me ! the difference between these two battery at the start is very small ! this is why i dont know if the lightweight has really a advantage vs bigger gaz thank ! next test = 21,5 & 13.5 with IP 7800 100c battery !
#32
some new about my car ! my friend and I work togetter for a new bottom plate desing made with 7075 t6 aluminum plate water jet cut. for the moment we look a chassi desing like the 417ffprototype from kentech because the base of the car is a touring car
https://kentech.wordpress.com/2016/0...4-development/
#39
The best is to talk with the machinist to see what type of files he needs and if he his able to source and work on the type of material you need.
Good luck!
Alexandre
#40
Got mine few days ago! Lovely kit to build. Parts have fit exceptionally well! Thumbs up to Spice!
Is anyone running 17.5 in theirs? What is the actual gearing for this beast? Can't wait to test it against my FF04 EVO black edition!
Cheers
Cheers
#45
Just looking from the pic of your FF.. your Lipo is farther back compare my set up..mine is up the front position...you might get more off power steering but less on power steering...seem to me the lipo in the front generated more front traction,....plus having lipo in the back will make the rear end a little loose around the sweeper...
