Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-05-2002, 04:56 PM   #61
popsracer's Avatar
Default Unknown
If something on your car, etc. is working fine for you then why change it ? Only thing I would do is check the wires and connections for signs of overheating. A bad connection will cause damage quickly at 20+ amps discharge rate.
popsracer is offline   Reply With Quote
Old 11-05-2002, 07:59 PM   #62
unknown's Avatar
Send a message via AIM to unknown
for now, i am going to make myself a bulb discharger with a Deans connector on the end. Then, once I get into it more, I will start making my own packs and get a better discharger that discharges each cell individually. I have seen some HOW TO's on making a bulb discharger. Some people say to just watch the lights, once they get dim, take the pack off. Others have a switch that will automatically stop discharge. Do you know where I can get one of these switches?
unknown is offline   Reply With Quote
Old 11-05-2002, 09:07 PM   #63
popsracer's Avatar
Default Cut-off switch
Deans has one avallible seperately that you can add (solder) on.
I just GAVE away a Deans bulb discharger at the track a few weeks ago. I was always forgetting to keep an eye on the bulbs so I bought an Integy, Reactor 20, auto cut-off discharger. Cheaper than the full Deans set-up also.
BTW, are you really using the Peak Maxx-packs? I've had alot of trouble with them myself. I have a pair in my starter box and one is starting to act up. The packs are also less than 3 months old.
Old 11-06-2002, 06:20 AM   #64
marvi's Avatar
Trader Rating: 48 (100%+)
Default Re: Re: Not so unknown
Originally posted by Iso Octane
I have a question... how long does it take you guys to charge your packs? For me, it's 40+ mins for 2400mah, 50+ min for 3000mah. At 4 amps (that's the max on my "within budget" charger). Are these respectable charging times?
about 45 minutes for a 3000mah @ 4 amps, but now, i charge at 6 amps for about 25 - 30 minutes. as long as my batteries peak at 9.20 to 9.30 volts and its not too hot after the charge, i know that theyre ok (im using unmatched SMHs)
www.marvivalves.yolasite.com
www.themangofarm.yolasite.com
marvi is offline   Reply With Quote
Old 11-06-2002, 06:39 AM   #65
marvi's Avatar
Default Re: Charge times
Originally posted by popsracer
There are formulas to calculate charge rate and time for the Mah of the pack. Maybe someone can post if they have them.
im not sure if this is the correct formula but here goes:
charge time (in seconds) divided by 3600. then multiply by the amp rate
for example, charge time is 1500 seconds and rate is 6 amps.
1500/3600 = .4167
.4167 x 6000 = 2500mah
i think this is the same value shown in the first gen. millenium after the end of each charge.
Old 11-06-2002, 08:38 AM   #66
popsracer's Avatar
Default Thanks Marvi
Thanks for providing this information for everyone to have.
Old 11-06-2002, 09:12 AM   #67
unknown's Avatar
I think I will pick up the Integy Reactor 20 then. Its only $40 and has an auto cutoff. Im not gonna mess around with watching the bulbs.
Old 11-06-2002, 09:22 AM   #68
popsracer's Avatar
Default Integy Reactor 20
I think I only paid $30 something for mine at the LHS. (was over a year ago) They also have a Reactor 30 but it's really for if you are running modified motors. You are trying to simulate the discharge conditions that the batteries see in your car.
Old 11-06-2002, 09:07 PM   #69
Iso Octane's Avatar
Thanks for the info!
Iso Octane is offline   Reply With Quote
Old 11-08-2002, 12:53 PM   #70
unknown's Avatar
Do they make 3000 and 3300 mAh Ni-CD battery packs? I went to the track yesterday with my 2400 mAh Ni-CD battery pack and asked them if they had any 3000 mAh Ni-CD packs....and the guys said...."Nope, we only have 1600 mAh Ni-CD battery packs...the rest are Ni-MH. Who makes them? And what brand should I buy?
Old 11-08-2002, 04:03 PM   #71
You could probably get 3000 mah Ni-Cds. They would just be D cells. hehe.
If you don't know you should get the 1600s.
Pit Crew is offline   Reply With Quote
Old 11-09-2002, 10:32 AM   #72
unknown's Avatar
So...there really is no such thing at 3000 or 3300 mAh Ni-CD batteries? I have a 2400 mAh. Is that as high as they go. Then after 2400...3000 and 3300 are Ni-MH?
Old 11-09-2002, 10:41 AM   #73
popsracer's Avatar
Default 2400, 3000 ,3300, AAAAAAAAAA!!!!!!
Yes you correct. There maybe some in between ratings, but 2400 is the top end of NiCd's and 3000 and up is MiMh.
What is better will probally be your next question. On this my experience is to 2400 NiCd's only. Alot of the Stock class racers that I race with use 3000HV's. No one will tell me for sure which is better. But by looking at how many people run what, you can get a pretty good idea of what the faster racers prefer.
I am probally going to get 1 matched 3000HV pack soon as I could use another pack in my arsenal of racing weapons.
Old 11-09-2002, 11:10 AM   #74
unknown's Avatar
OK, now that I know that. I have a 2400 mAh pack...
What if I get a 1800 mAh pack. Will that offer me less run time...? Or less power?
Old 11-23-2002, 06:22 AM   #75
not less power less run time ni-cads u have to train to have more power they nic metal don't have the memory propreties like ni-cads. what i mean is u have to discharge ni-cads at a high amp rate to bring voltage up then i re match batteries to get the best voltage packs volts= speed in stock racn today's battery techno.u don't have to worry about run time in stock class i still run 2000's and still run good against 3000 hv,don't get me wrong i still have my share of 3000hv's.................bubba
bubbaicm is offline   Reply With Quote
Forum Jump
tekin battery doctor 8.0 & fk05 battery brace xxblackheartxx2 Australia For Sale/Trade 0 04-02-2008 12:33 AM
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 08:47 PM
33 Promatch 3300 NIMH battery cells and Battery Case nitro468 R/C Items: For Sale/Trade 10 08-06-2007 04:21 PM
FS: New Lipo battery 8000mah 7.4v fits in most battery trays aussiebuddha Australia For Sale/Trade 0 11-22-2006 02:23 PM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 05:07 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
