Like Tree15Likes
Old 01-29-2017, 01:59 AM   #121
Originally Posted by Hessanator View Post
Is it stiffer, lighter,or...advandages? Over the Destiny aluminum chassis?
It's a bit stiffer than the destiny chassis and it's also narrower to prevent rubbing.
Themelisfactor1 is offline   Reply With Quote
Old 01-29-2017, 06:22 PM   #122
Very good results out of this chassis so far....
bertrandsv87 is offline   Reply With Quote
Old 02-03-2017, 07:02 AM   #123
Trader Rating: 18 (100%+)
the roche site carries replacement parts now as well just an FYI
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 02-14-2017, 05:33 AM   #124
Ok, i'm about 2 meaningful races in with this car and 5 total race/practice days and the consistency in laps that i'm putting down with this car is mind blowing for me. i'm loving the car itself. I dont know if it's an elevation of my driving finally or the car being that awesome, but i'm loving it. hope the parts support will improve with it, i'd like to stick with it.
Old 03-02-2017, 08:31 AM   #125
antlockyer's Avatar
I've just bought a Destiny. My first real attempt at touring cars. I had a Yokomo back in the 90s but only used it a couple of times and never really had a clue what I was doing. I've been racing 12th scale for about a year so have a little more knowledge now but not much
antlockyer is offline   Reply With Quote
Old 03-08-2017, 07:12 AM   #126
where are yall running your rear sway bar links? to the outer or inner balls on the rear arms on high grip carpet?
also anyone hear of a stiffer carbon chassis for destiny?
Old 03-09-2017, 08:20 AM   #127
antlockyer's Avatar
Guys any clue on what way round the centre pully goes. the instructions are hard to work out there (and it seems to fit perfectly well either way).
EDIT
If this is the right way round I've done it correctly.
http://www.redrc.net/wp-content/uplo...inyRX10S-4.jpg
Old 03-09-2017, 08:36 AM   #128
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
Per the instructions...
Mach10_shooter is offline   Reply With Quote
Old 03-09-2017, 08:59 AM   #129
antlockyer's Avatar
That is not obvious to me at all.
Old 03-09-2017, 09:55 AM   #130
It says to install short belt on the screw head side of the pulley not the side with the threads... You can only install it one direction!
Old 03-09-2017, 10:47 AM   #131
antlockyer's Avatar
Thank you, I just cant see it on that picture at all for some reason.
Old 03-17-2017, 04:25 AM   #132
there's a lack of setups for this car especially on carpet on the petit website. i'm far from the fastest, but i put up my setup so others can have something to look to. anyone else going to do the same?
Old 03-17-2017, 04:58 AM   #133
I have a very good light to medium grip gray carpet setup I'll post soon.
Old 03-18-2017, 03:43 PM   #134
Default NEW CENTER WEIGHT
Check this out! Bad timing with the factory Destiny weight coming out but this one is only 35g. The Destiny part is 50g, far too heavy if you are running aluminum chassis. Pricing is comparable at around $20 Questions and orders can be placed if you contact [email protected]
There are other items in the works for the Destiny and I'll post those as soon as information is available.
Castradamus and jasonb like this.
Old 03-18-2017, 09:41 PM   #135
Great....
