Like Tree13Likes
Old 12-13-2016, 05:13 AM   #76
Trader Rating: 18 (100%+)
random...but those the gear diff is interchangeable both front and rear right? it's not a different part number?
http://www.destinyracing.jp/index.ph...product_id=104
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 12-13-2016, 08:01 AM   #77
RBLove's Avatar
Trader Rating: 72 (100%+)
Yes - the diffs are internchangeable front and rear.
RBLove is offline   Reply With Quote
Old 12-13-2016, 09:00 AM   #78
cool thanks
Old 12-15-2016, 05:42 AM   #79
is there any brands that have interchangeable bladders with this chassis' shocks? i really dont want to drill a hole in the caps just to get rebound when i was able to do that with my TC7 shocks with a simple bladder swap
Old 12-15-2016, 08:22 AM   #80
Trader Rating: 15 (100%+)
Yokomo bladders will fit well.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 12-16-2016, 07:18 AM   #81
Trader Rating: 32 (100%+)
What bladder you use for TC7 shocks??
hobbs is offline   Reply With Quote
Old 12-16-2016, 07:27 AM   #82
i tried those in my TC7 and they didnt allow me to set my rebound either
i used TC6.1 bladders
Old 12-16-2016, 07:35 AM   #83
RBLove's Avatar
phatboislim, what are you trying to accomplish? Full rebound, partial, or none? I only race on carpet and typically build my shocks with little to no rebound. I have been able to accomplish with the kit bladders. It took some time, but was able to do it. Building them with rebound I found very easy.
Old 12-16-2016, 08:04 AM   #84
i'm trying to get zero to little rebound, but when i go to try to set it as such the shaft always extends out once i get the cap closed. i'd like to see the method (youtube/some kind of video) yall do in order to get zero/little rebound with the kit bladders because i couldnt get it. i sat on my couch working at my table trying time and again with no ability to get them built as such.
i race on the new black crc carpet
Old 12-16-2016, 08:33 AM   #85
Trader Rating: 30 (97%+)
just drill the cap
zaraz is offline   Reply With Quote
Old 12-16-2016, 09:13 AM   #86
RBLove's Avatar
Drilling the cap does work, but you need to keep the shaft moved in while screwing on the cap extremely slow. Alexander Hagberg has a youtube video on building Xray shocks with zero rebound and they are basically the same thing. I will see if I can find it.
Old 12-16-2016, 11:07 AM   #87
Originally Posted by zaraz View Post
just drill the cap
To be honest after being able to do shocks with the rebound i want without drilling i really dont want to drill my shock caps.
I'll look for the video too thanks for a direction to at least look
Old 12-16-2016, 11:47 AM   #88
if xray caps are the same then xray sell the option caps with the holes already in them which will get you 0 rebound, I have tried building without the hole in the cap and never got 0 rebound, good luck hope it works for you.
Old 12-16-2016, 03:47 PM   #89
Found alexander vid...followed it and reduced my rebound but not by much... from full rebound to maybe 30- 40%
Old 12-16-2016, 03:58 PM   #90
Racermac73's Avatar
Your putting to much thought into this.. push the shaft 75% in, shove the bladder in until it pushes out fluid and seals itself to the shock body, screw the cap on.. all this other nonsense is just brainfukin it and wasting your time.
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
