Like Tree15Likes
Old 03-19-2017, 05:46 AM   #136
Trader Rating: 18 (100%+)
waiting for that whisper of a stiffer carbon chassis to come to fruition
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 03-20-2017, 04:35 AM   #137
antlockyer's Avatar
Anyone using the battery bracket set?
antlockyer is offline   Reply With Quote
Old 03-20-2017, 06:06 AM   #138
Yes what would you like to know?
**Destiny RX-10s**Futaba**Trinity**Montech**SpeedyRC
Madmaxaus is offline   Reply With Quote
Old 03-20-2017, 06:11 AM   #139
antlockyer's Avatar
Is it worth buying?
Old 03-20-2017, 07:19 AM   #140
Is it worth buying?
Yes they are helps keep the battery in place plus it adds some weight on that side and no tape under the chassis
Old 03-20-2017, 07:32 AM   #141
antlockyer's Avatar
Cool thanks, will get one.
Old 03-20-2017, 08:47 AM   #142
what kind of screws are you all using? wanting to shed weight so i can add some to the motor side of the chassis
Old 03-20-2017, 02:55 PM   #143
Destiny - moodyfools
phatboislim likes this.
jasonb is offline   Reply With Quote
Old 03-20-2017, 03:03 PM   #144
antlockyer's Avatar
Same for me. Great quality, well packaged and the reference sheet saying what page to look at for each screw is very helpful.
Old 03-21-2017, 05:49 AM   #145
THANKS!
Old 04-11-2017, 07:44 AM   #146
anyone with a high traction carpet setup? if not i'm going to look to a BD8 setup
Old 04-11-2017, 07:47 AM   #147
Mach10_shooter's Avatar
Trader Rating: 37 (100%+)
If you are looking for a good stock setup I can get you mine. Ran on CRC black carpet a few weeks back. By far the fastest car there & handled perfect. I'll try to get it posted up tonight.
Mach10_shooter is offline   Reply With Quote
Old 04-11-2017, 08:32 AM   #148
i have a good setup for a low-medium grip..i need something for real high grip black carpet. there's one track i cant seem to get my car to drive right on it. highest grip black carpet i've run on to date. if it's a high grip setup, i'll definitely check it out.
Old 04-11-2017, 10:16 AM   #149
antlockyer's Avatar
Hi all question regarding droop. I've got my droop screws set as per the manual. The rear has 6mm over ride height but the front only about 1.2mm, should I wind the screw back in to get to the 6mm figure?
Old 04-11-2017, 10:49 AM   #150
i havent run over 2.5mm ORH personally
