What size wheel for touring car
Hello,
I see wheels advertised that are 28, 26 and 24mm for sedan. What size should one run? Thanks............. |
The size u are refering to is the width of the tire. The wider the tire the more grip but u have to make sure that they don't rub on the suspension. Generally run wider tires on the rear than the front.
28mm is pretty much the standard on the rug with foams...
24mm for the asphalt with Rubber |
I know for foams on carpet everyone runs 28mm. For asphalt I know they dont run 28mm. I think it is 24 or 26 depending on preference.
Thanks for the info guys. Does anyone running Electric touring car run nitro shoes?
Generally, no. But I do know that the user "teamgp," who frequents this website has used them in the past, with good success.
-Josh |
Good Luck. :D |
