Old 02-03-2016, 09:05 AM   #1
theproffesor's Avatar
Trader Rating: 56 (100%+)
Default Yokomo spring rates
I just purchased some Yokomo springs for my cars. I bought pink, purple, blue, and black. I know everyone prodominately runs pink/blue. I know the order of stiffness. What I can't find difinetivley (I've googled and get different rates for the same spring) are the actual spring rates. I'm a bit OCD when it comes to knowing this. I would also like them so I can swap out my current spring with the closest comparable Yokomo Spring. Could anyone help me out?
Thanks in advance
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 02-03-2016, 09:55 AM   #2
rcnickv's Avatar
Default Rsd
Here they are thanks to reflex racing
One thing to consider with yokomo springs is that while some may have a similar rate to others, they have a significantly different feel on track because of the wire used and coil pattern.
reginafastraxx.com|WCICS
Nick
rcnickv is offline   Reply With Quote
Old 02-03-2016, 10:32 AM   #3
I've looked through that list, it's missing the Yok purple and I was wondering the accuracy of that list since there are 2 springs between the Yok pink and blue
Old 02-03-2016, 10:35 AM   #4
I've measured the purple before and its exactly the same as a pink regardless of what yokomo claims.
rxmeador is offline   Reply With Quote
Old 02-03-2016, 11:05 AM   #5
rcnickv's Avatar
The two between pink and blue are yellow and purple. The yellow is in that list but is not placed between because the real world testing showed that it is in fact stiffer than the pink. The yellow having significantly less coils making it much less progressive than the pink. The purple will have a nearly identical rate (maybe slightly softer or more progressive) to the pink as it is the same wire thickness but 0.25 coils more than the pink(6.75 vs 6.5 coils).
There is a more complete chart available here
Nick
Old 02-03-2016, 12:46 PM   #6
Thanks. That chart was very helpful
Old 02-03-2016, 01:14 PM   #7
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Have you tried hpi silvers yet? I switched to these on my 17.5 car and they worked better than the yok blue/blue I had been using.
Josh-n-ya is offline   Reply With Quote
Old 02-03-2016, 02:07 PM   #8
Keep in mind, the Petitrc chart was made in 2008. Some of the current springs weren't even being manufactured at that time. That chart can help but can be confusing as well. Take the Yokomo purples for example, if you look at the chart you will see yokomo purples with a high spring rate. Those are not the current Yokomo purples that are part of the (L) series.
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 02-03-2016, 03:15 PM   #9
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
They are not actually the same
Feel very close, in fact I find it's interesting how close many springs are in rating, but feel so different on the track
Note:
.25 turn difference between Purple & Pink springs
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-05-2016, 03:59 PM   #10
Note:
They don't look the same because purple has .25 more coil like you said but the spring tester says they are the same rate.
Old 02-05-2016, 05:03 PM   #11
What spring tester are you using ?
.25 turn difference is going to require a very accurate tool to measure
Old 03-06-2017, 01:11 PM   #12
kewdawg's Avatar
Default Progressive/Linear Mix?
Guys are there typical progressive and linear spring mixes used? For example: Yokomo Pink (progressive) front and HPI Silver (linear) rear
kewdawg is offline   Reply With Quote
Old 03-06-2017, 01:41 PM   #13
HPI silver is a quite progressive spring!
http://www.rcweb.de/index.php/Thread/17416-Federmessung/?pageNo=1
In this german forum i (The worst) have made some graphics and comparisons...
Maybe you convert language with google...
Worst87 is offline   Reply With Quote
Old 03-06-2017, 01:48 PM   #14
Metalsoft's Avatar
Trader Rating: 69 (100%+)
I use Tamiya blue front and yokomo Blue rear for Black CRC high traction carpet..
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 03-06-2017, 02:27 PM   #15
veecee's Avatar
There are many T4 setups on Petitrc that use progressive fronts and linear rears. Seems popular for carpet and higher traction tracks
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
