Turnigy 60a Sportsman esc >
Old 01-19-2016, 09:09 AM
Default Turnigy 60a Sportsman esc
Has anyone used this esc yet? I got one and set it up with my programmer. They do not mention boost and timing in the literature but they do show up as options on the programmer. I set a boost number and the esc still blinks but there isn't a noticeable difference in the motors performance. Same with the turbo setting. I don't know if it has been submitted to ROAR but if it is and it truly matches the XR-10 Hobbywing then we have a game changer at $28.
I will have it on the track this Saturday and will play with the timing settings to see if they really have an affect on the track.
old_dude is offline
Old 01-19-2016, 09:11 AM
SRC_DRIVER's Avatar
Trader Rating: 65 (100%+)
Hows the overall quality of it look? Any pictures of yours? Actual product?
SRC_DRIVER is offline
Old 01-19-2016, 10:07 AM
howardcano's Avatar
Trader Rating: 37 (100%+)
The Trackstar 60A Sportsman, #9052000082-0, has been submitted. The timing can't be changed; the programmer options have no effect.
howardcano is offline
Old 01-19-2016, 01:05 PM
Thanks Howard, it seemed like they had no affect. I tried contacting Turnigy and that is like talking to a wall.
As to the quality, it looks very good. Footprint is similar to the old Hobbywing Juststock but a little heavier due to a substantial, thick finned heatsink. I did not weigh it. Here is a link to it.
http://www.hobbyking.com/hobbyking/s...dproduct=74585
old_dude is offline
Old 01-19-2016, 01:22 PM
sbd
This trackstar ESC seems to be a variant of skyrc Toro TS50 - G-force.
sbd is offline
Old 01-20-2016, 04:00 AM
Just a different outer wrap which includes the heatsink.
It would not communicate to my computer via my programmer box like my Gen II's do but that box programs it.
old_dude is offline
Old 01-20-2016, 04:47 AM
SteveM's Avatar
Trader Rating: 165 (100%+)
I have used both of the above speed controls and they are the same and work well. Never tried the Turnigy.
SteveM is offline
Old 01-20-2016, 07:49 AM
DBM
Good to hear that it has been submitted for roar approval. I'm always looking for good affordable electronics to recommend to new people getting into the hobby.
DBM is offline
Old 01-21-2016, 04:50 AM
I was looking at the Turnigy manual and they even left the reference to the TS50 in it.
old_dude is offline
Old 01-24-2016, 04:55 AM
OK I ran this esc for the first time yesterday. I am very impressed. Once you understand Turnigy's deadband settings the drag brake became very responsive to adjustments. The drag brake is a very important tuning tool in some onroad classes and I was running 25.5 F1 which uses a weak rotor. This esc is very smooth and there was not a hint of heat on the unit. I feel it may be the best under $50 esc out there maybe best under $100.
old_dude is offline
Old 01-26-2016, 02:45 PM
A little more testing and I found something interesting. I decided to try this esc with a 1 cell. It has a setting for cutoff voltage that can be set as low as 3 volts. Connected to a 1 cell all of the radio gear and the servo work but the motor will not run. Next I connected a booster. Same result. Has anyone else tried this? This is only the second esc that I have seen that does this, the other being the Castle Mamba 2 cell edition.
old_dude is offline
Old 06-01-2016, 10:57 AM
sbd
Hi,
A very late responce, but I the low voltage protection is for a cell. So when you select 3 volts the ESC will cut power at 6V input voltage. So you may try to switch off the V protection and and then it may work.
sbd is offline
Old 06-09-2016, 03:49 AM
Hi,
According to the manual it is actual voltage. There is no setting for off. I actually blew up my first one by hooking it up backwards (dumb mistake). I have a new one to try. The Toro unit says 1s min. in its manual!
old_dude is offline
Old 06-09-2016, 10:29 AM
Biff73's Avatar
I have 2 of this esc,you will need this program card to program it or it comes default forward & brake only
http://www.hobbyking.com/hobbyking/s...ckstar%20multi
Biff73 is offline
Old 06-09-2016, 10:55 AM
I already have the card. For ROAR events it requires a firmware upgrade also to 2.01 done by using the card, cable, PC and the latest software from Turnigy. I have 3 genII's which use the same programmer.
old_dude is offline
