Old 11-14-2005, 01:06 PM   #1
kyle "hitawall"'s Avatar
Default motor efficiency
what is the best way to get the most efficient stock motor.
kyle "hitawall" is offline   Reply With Quote
Old 11-14-2005, 01:40 PM   #2
sosidge's Avatar
Narrowing the brushes to the width of a standup would increase the efficiency somewhat.
But stocks are not efficient motors - they are set up to produce the maximum power from the limited spec. Efficiency is not the best way to do this.
Old 11-14-2005, 01:45 PM   #3
TeamPink91's Avatar
Send a message via AIM to TeamPink91
This wouldn't happen to be for the endurance race would it kyle?
TeamPink91 is offline   Reply With Quote
Old 11-14-2005, 03:32 PM   #4
Narrowing the brushes will do the trick if you have to use a stock motor. If you have open rules we used to run a 21x1 spec arm in a mod can and run it at around 12-18 deg timing. I ran a motor like this in T-3 for 8 min races and it was with sanyo 2400's.
jeffb is offline   Reply With Quote
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 04:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 02:36 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 10:22 PM
increasing combustion efficiency.. and some engine problems NTC3 Racer Nitro On-Road 6 06-17-2003 07:18 AM
One-ways and efficiency Q Cole Trickle Electric On-Road 28 02-10-2003 04:43 AM
SEO by vBSEO 3.5.0
