Old 01-04-2016, 06:36 AM   #1
Luppi Stefano's Avatar
Default Capricorn Lab F1-01
here You Can find the manual
http://www.capricornrc.com/capricorn...0Rel%201.1.pdf
Who run this F1 Chassis?
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 01-04-2016, 08:13 AM   #2
This is my
very good built
rear height adjustable with shim
caster adjustable only loosen 3 screw and slide the caster block
Capricorn Lab F1-01-p_20151224_230210.jpg   Capricorn Lab F1-01-p_20151225_015549.jpg   Capricorn Lab F1-01-p_20151224_161550.jpg
Lab F1-01
Old 01-15-2016, 04:27 PM   #3
no one?
Lab F1-01
Old 01-15-2016, 07:11 PM   #4
AMZ
AMZ's Avatar
Beautiful F1 car, more pics would be nice !!
AMZ is offline   Reply With Quote
Old 01-18-2016, 04:20 PM   #5
other Pic of Car
some info
-easy Adjust Rear Height, with shim
-big bore high precision Shock
-float servo mount
-easy caster Adjust
-front roll center adjustable with shim
Capricorn Lab F1-01-p_20160119_000032.jpg   Capricorn Lab F1-01-p_20160119_000042.jpg   Capricorn Lab F1-01-p_20160119_000049.jpg   Capricorn Lab F1-01-p_20160119_000058.jpg   Capricorn Lab F1-01-p_20160119_000122_ll.jpg
Lab F1-01
Old 01-18-2016, 04:23 PM   #6
part 2
Capricorn Lab F1-01-p_20160119_000138_ll.jpg   Capricorn Lab F1-01-p_20160119_000220_ll.jpg
Lab F1-01
Old 01-19-2016, 10:43 AM   #7
The way the rear pod ride height adjustment and wing mount was designed is very interesting. I like the servo mount too. The lower front wishbone design makes me nervous though... whenever I see 2 screws close together holding the pivot ball assembly I think tweak but I can't say that I have tested this. Overall it looks very good.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 01-21-2016, 05:29 AM   #8
yes, rear height adjustment is very good
for now I haven't problem with front Wishbone
I run this car from 1 month, many test days and one race, I broke only Right kingpin in a BIG BiG Crash, Im very Happy!
Lab F1-01
Old 02-08-2016, 04:17 PM   #9
some new upgrade for LabF1-01
Rear pivot Alu 7075
Rear pod plate Metal
side spring mounts alu 7075
bodymount plate Alu 7075
Lab F1-01
Old 02-12-2016, 09:14 AM   #10
gsxr0311's Avatar
Trader Rating: 19 (100%+)
This looks like a very nice car. I like the rear ride height and the caster adjuster. Have you tested the battery sideways as opposed to in line?
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 02-12-2016, 03:48 PM   #11
is no possible to switch trasversal battery, this car is only in line Battery, but...never say never
we try some new parts for the future...and works really really good
it would be nice to share ideas and setup with other drivers
Lab F1-01
Old 03-29-2016, 10:23 AM   #12
gsxr0311's Avatar
Hello,
I would like to get this car but there is little support here in the u.s.
Do you know if the 200mm pan car will ever be made for 235mm?
Old 07-19-2017, 02:14 PM   #13
British Menace's Avatar
I am looking at getting one of these.
I see RCPLANET have everything we will need here in the US so should be good to go ...
I do like the way the car is built. Just never been a fan of "Pan Style" rc car's.
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 07-19-2017, 04:29 PM   #14
thisguy2849's Avatar
Regards
BM
Rctarget.com is us importer. They have everything
thisguy2849 is offline   Reply With Quote
Old 07-19-2017, 08:37 PM   #15
Yes. Sorry. RCTARGET. Thats what I meant to say. Either way. At least we have a place to get our parts for the car
Regards
BM
