Old 02-28-2003, 08:18 PM   #1126
for sale evo III am from covina Cali. and only ran it 4 times
mugenracer is offline   Reply With Quote
Old 03-01-2003, 01:53 PM   #1127
Holmenkollen's Avatar
Default Diff balls
Im just wondering, how long should the standard diff balls last?
Ive changed everything except the diff balls in my rear diff and it still feels extremely gritty. Very strange.
Holmenkollen is offline   Reply With Quote
Old 03-01-2003, 04:03 PM   #1128
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Most of the time a diff is crunchy is because of the thrust ball assembly. I don't have a evo3 but if it uses the standard tamiya one piece trust bearing it is kind of hard to get it clean enough. I would soak the thrust assembly in some cleaner and blow it out with compressed air and grease it with some good tacky grease and try it again.
KINGZJ is offline   Reply With Quote
Old 03-01-2003, 06:46 PM   #1129
lee82gx's Avatar
i agree with what KINGZJ said.
i also had this problem to some degree with my old car.
what u have to do is remove the diff balls and clean thme the way u like and also clean the diff's very thoroughly.normally if u just clean it with the balls in ,dirt will still get attached to the balls.
lee82gx is offline   Reply With Quote
Old 03-01-2003, 08:04 PM   #1130
hi there... I have the same problem with my 414m... crunchy as conflakes, is my diff...
is there any other thrust bearing we can use? does this affect performance in any way?
jwwu is offline   Reply With Quote
Old 03-02-2003, 09:27 AM   #1131
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Post EVO 3 4x4 config
Difuser,
I made some of the changes we talked about to try and come up with a decent 4x4 config for the Reedy...so far so good.
Still seems to park a bit at mid corner, but shows some promise
madjack is offline   Reply With Quote
Old 03-02-2003, 10:59 AM   #1132
Aluma's Avatar
well, had my first run with the evo3 with ball diff up front. I set up it up 2 camber, 0toe, a block rear, bout 6mm ride height. yellows up front, reds out back. It understeers on power, but rotates nicely off power. ran with a Monster PRO geared 72/24, 72/25, 72/26...it got slower with the last gearing, but the 72/25 let me get a 12.8 sec lap at my track! Its fast! Its smmooottthhhh! although I did notice some scratches at the very front of the chassis and one on the rear of the chassis...guess I better increase ride height a tad. Next time I'm going to try the 72/23 and keep going lower to see what it does. THat monster motor is weird to get a nice gearing. I gotta change the setup....I need more onpower steering. IF y'all find a good setup for bumpy outdoor asphalt, please share.
Aluma is offline   Reply With Quote
Old 03-02-2003, 08:02 PM   #1133
Aluma's Avatar
hey guys, just out of curiosity.... I'm geared at 72/25...what would happen if i switch to a 66/23(basically the same ratio)?
do I get more punch or do i get more top end? or both?
Old 03-02-2003, 08:13 PM   #1134
rayhuang's Avatar
I ran my EVo this morning at my track and carpet was cold from not being used in two weeks and ambient temperatures in building of 40 degrees!!! So-car had a on-power push that was hurting the performance, but it turned in well enough and seems like it is carrying the speed through the corner untill the front tires give up the ghost at mid-corner. But i know how to fix that real quick and when get more testing done with it-I'll start posting my set-up (if its fast).
I geared 34/90 with 2.35" tires on a Monster. Motor was too hot-so i think i need to go down one tooth for starters. Car was smooth and whiper quiet. I think i also need to relearn driving with a one-way. This is my first car with one have ever had. Maybe I just need to lift earlier and power through corner like with a solid axle.
Old 03-02-2003, 10:10 PM   #1135
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
Top end. Unless you're running a torquey mod motor you won't get any punch out of that gear combination (I almost learnt my lesson the hard way).
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 03-03-2003, 05:18 AM   #1136
I was reviewing the "smoking" carpet setup posted a couple pages back and I have a few questions.
1- Are the 1.5 mm spacers used on the rear toe blocks from the "53539 Tamiya 5.5 Aluminum Spacer Set" package?
2- The Front and rear width are said wider. Front by 1mm (blue spacer) and rear 2mm (red spacer). What is the part number for these spacers?
3- Shock oil weight is referred to as "400" & "500". Anybody know what American weights these translate to?
4- Can someone explain the "rebound stroke" measurement and how to take it?
Thanks!
ARC MotorSports is offline   Reply With Quote
Old 03-03-2003, 08:57 AM   #1137
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Thanks!
1. yes the spacers are from the 5.5mm spacer set.
2. the spacers are part number 53448.
3. i think that i posted that i used 40 and 50wt oil, but in case i didn't, i used 40 and 50wt associated oil.
4. to measure the rebound stroke, you remove you wheels and shocks, place your chassis on something flat (setup board, glass, etc.) and then measure from the top of the axle to the board.
hope this helps
peter
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 03-03-2003, 10:11 AM   #1138
rayhuang's Avatar
Default Diff
Peter and everyone else-has your rear diff been staying tight? Mine has loosend up three times now. Also-how tight are you running yours? in other words-when you fully tighten the diff screw-how far back do you unscrew it (1/8, 1/4 turn, etc.).
Thanks guys,
Ray
Old 03-03-2003, 10:20 AM   #1139
Aluma's Avatar
loosen? why? i just tightened it up and thats it.... maybe the loctite helps
its funny though, the rear diff is supersmooth, but the front diff I put together has a slightly crunchy feel and sound. Less than the evo2, but crunchy nonetheless.
ummm bout them spacers...why dont you just use the plastic ones that offset the wheels? Its basically the same thing. I think integy also makes aluminum clamp spacers which offset the wheels from 0 to 5mm...very nice.
Old 03-03-2003, 10:24 AM   #1140
Peter - Thanks, I'll give that a shot and order those spacers.
rayhuang - so far my diff is holding its setting in the rear, I have the one-way in the front.
Aluma - I'll check that Integy stuff out.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
