Old 02-28-2003, 06:30 AM   #1111
Originally posted by lee82gx
hi all
i have finally received my Evil III!!!!
got some assembly questions:
1.Im new to Carbon fibre..so should i use thick or thin CA to seal the edges?
2.how much should i file on the battery slots for side x side packs?
3.what else should i know??
thanks..
1. First, sand all the edges of your CF parts. I used 400 grit sandpaper to do this. If you have some, wear latex gloves and a respirator. I used a thin CA to seal the chassis. I soaked the tip of a Qtip with the CA, and then I lightly applied it to the sides of the chassis and battery slots. Be careful with the CF pieces, they are very sharp before sanding.
2. I beveled the corners of the slots slightly. The way to get the best results is to only take a very little amount chassis material off at a time. Keep a battery pack handy to test its fit. You don't want the battery hanging below the chassis line.
3. Take your time and use thread lock on all screws threading into aluminum.
Good Luck!
ARC MotorSports is offline   Reply With Quote
Old 02-28-2003, 06:36 AM   #1112
lee82gx's Avatar
Thanks Maui and ARC
i'm clearer now..but i already sealed them just now.will be assembling on sunday as i have to take my final exams..
threadlock :check!
hope to have maiden run on monday..
i realised there isnt a diff in the front?how come?do i have to buy one set...?that sucks.
lee82gx is offline   Reply With Quote
Old 02-28-2003, 07:04 AM   #1113
I have tried other cars with a one-way in the front and never had any success. They were all twitchy and had too much steering for my taste.
The Evo III with its one-way is very fast, yet very balanced. Rear traction is also very good with the one-way. So go ahead, drive it with the one-way, you'll like it!
Old 02-28-2003, 11:04 AM   #1114
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
my evo made its maiden voyage last night... just practice. very smooth and balanced. still waiting on the outdrives for the front ball diff though. still run right out of the box settings, on Skid-Not surface. veeeery fast, even with a practice (terd) motor!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-28-2003, 02:14 PM   #1115
Trader Rating: 24 (100%+)
Hey EVO 3 drivers...can you help out a poor EVO 2 driver!! Want to know if the spur gear adaptor for the EVO3 will fit on the EVO2?? Thanks
Evoracer is offline   Reply With Quote
Old 02-28-2003, 02:17 PM   #1116
izzyracer's Avatar
No! you can't, as far as I know the EVO 2 has a totally different Spur gear set-up
izzyracer is offline   Reply With Quote
Old 02-28-2003, 02:25 PM   #1117
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Bong... este... Izzyracer,
Are you sure it won't fit? The shaft on both cars looks the same, probably with a little tinkering, it should work... no guarantees though... =)
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 02-28-2003, 02:26 PM   #1118
eeyan's Avatar
I'll bring both cars tomorrow to TA and we'll check it out...
Old 02-28-2003, 02:35 PM   #1119
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I know what will work
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-28-2003, 02:42 PM   #1120
izzyracer's Avatar
I did not know you have an EVO 2
Old 02-28-2003, 02:50 PM   #1121
Wow...don't tell me I stumped you guy's??? Maybe somebody knows where I can get a Cross spur adaptor?? Thanks all
Old 02-28-2003, 02:53 PM   #1122
rc-zombies's Avatar
Cross stuff try Rcmodel, Control Centre, jet Hobbies all in HK. or RainbowTen in Japan.
Good luck finding Cross stuff... the Factory burned to the ground a few months ago.
Old 02-28-2003, 03:07 PM   #1123
I don't think it will the new shaft for the E3 has 2 holes I presume 1 is for the old spur 1 for the new spur/adapter
D
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 02-28-2003, 03:10 PM   #1124
Talking Try Jet Hobbies
When I was there in December they had a "TON" of Cross stuff
90% chance they will have what you need
-Dave
Old 02-28-2003, 04:10 PM   #1125
Thanks guy's !! Yeah..already knew about the Cross factory...what a shame. Hope they come back.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
