Old 02-26-2003, 04:44 PM   #1081
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Transponder Mount
Originally posted by Yokio
Hi guys,
Is there a transponder mount available from Tamiya for the TB EvoIII?
I need a part#.
Not available from Tamiya....
but Sqaure Makes one .. so does TECH and The Alex Racing Barracuda PAL version transponder/ servo mount works..
Square EVOIII parts link
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-26-2003, 05:07 PM   #1082
Ok I've managed to test the Tech Racing ring gear plate on the front diff.
The verdict? It works but does not completely solve the problem.
It does protect again minor frontal taps but does nothing for harder taps. This still makes it a worthwile investment.
This is because of what Difuser said. On high traction tracks the tires of the car bite into the surface and transfers and incredible load onto the front diff gears which is the weakest point of the car.
On low traction tracks the tires may break traction and wheelspin which may protect the front diff gear.
Using a full diff at the front helps because the diff can slip a little when you hit something. With a one way there is no slip.
The front diff is just not strong enough to handle the load. If Tamiya are working on a fix it will most likely involve replacing the front gear with one that is significantly stronger. This may end up transferring the load elsewhere along the chassis which could move the problem elsewhere
In any case I'm still happy with the Evo3...although I would be happier if I didn't have to replace the diff gear after every race meet The results from the Thai race shows what it can do in more capable hands (ie. a person that crashes less).
itchynads is offline   Reply With Quote
Old 02-26-2003, 05:27 PM   #1083
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default TCS sa P.I.?
Pare, you have Tamiya organize races there sa Davao?
izzyracer is offline   Reply With Quote
Old 02-26-2003, 05:31 PM   #1084
izzyracer's Avatar
Default Re: Re: Transponder Mount
-Dave
COOOOOL! Will it make my transponder count faster?
Old 02-26-2003, 05:34 PM   #1085
izzyracer's Avatar
As soon as I ad an additional TA04 bumper on top of my TBevo3 one, I have not mess up a gear even from wild crashes. The Bodies still fit perfectly
I'll post pix lates!
Old 02-26-2003, 05:48 PM   #1086
lee82gx's Avatar
Default Re: Re: Re: Transponder Mount
if ur transponder count faster u'll have slower lap times dude!
lee82gx is offline   Reply With Quote
Old 02-26-2003, 06:02 PM   #1087
Talking
*DOH*
-Dave
Old 02-26-2003, 06:17 PM   #1088
izzyracer: I've tried replacing the stock bumper with a TC3 foam bumper which is thick and soft but it didn't help. Which car body are you running?
Old 02-26-2003, 07:09 PM   #1089
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Default Re: Evil 3 is the bomb-biggity
[QUOTE]Originally posted by rtypec
[B]How good is the Evo3?
Rod,
It appears that I'll be joining the fun on Tues. at So Cal in the near future (finally finished rebuilding the Enduro car) ...would you be willing to send me your So CalE3 set-up....buddy....friend!
thanks,
John
[email protected]
http://groups.yahoo.com/group/tamiyatrf/
madjack is offline   Reply With Quote
Old 02-26-2003, 07:19 PM   #1090
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
-Dave
Somebody tell JustRC to import Square's product to the US please!!
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 02-26-2003, 07:28 PM   #1091
MauiBuilt Racer's Avatar
How good is the Evo3? Well, after the chassis on my 414M2 broke from a major stuffing running modified, I threw down the Evo3 after a half pack of practice to trim it out and guess what?
Top Qualifier for PRO STOCK SEDAN:
ROD C with 30/5:08.48
Tehehe, okay enough chest thumping , too bad I had radio problems in the main and retired after one lap. Patt T's car was dialled and kinda had me wondering...MauiBuilt, where have you been man? I'm begining to suffer the same radio problems you have been getting and its getting expensive to fix broken cars doh!
Howzit goin R!!
Good job on the TQ man! Anyway I havent been racing for a while because of the glitching problem. I ran out of front one way ring gears so I had to wait for Tamiya to send me some. And about your glitching problem, The thing about the monster stock motor is that the paint on the can is thin. So when the paint wears off of the bottom of the can it causes big time glitches because of the metal to metal contact (motor plate & motor can). I found that out last night so i just switched to a new can and Voila!! glitch problem solved. I also took the whole day off to go down and do some major set-up changes today. After the end of the day, I finally got this car dialed. (Part of it thanks to Mr. Dan) good looking out! Hope to race with you soon!
JM
MauiBuilt Racer is offline   Reply With Quote
Old 02-26-2003, 08:41 PM   #1092
izzyracer's Avatar
Mine almost cover the whole front area.
I'm currently using a Modena!
Old 02-26-2003, 09:03 PM   #1093
Just my opinion the car looks good drives good but if you dont have one dont buy one unless you like driving it with out a front one way. or untill there is a fix for the front oneway gear. as of now the cars are defective.
mugenracer is offline   Reply With Quote
Old 02-26-2003, 10:24 PM   #1094
Trader Rating: 28 (100%+)
Default defective,Maybe....
Don't buy one?I wouldnt say that as a blanket statement.The car in manys opinion is better then the 414,I deal with the front one way issue untill there is a fix is to buy one way ring gears.Just bought 15 and after 3 race days only replaced 1 so far.
racenut123 is offline   Reply With Quote
Old 02-26-2003, 11:07 PM   #1095
TRF-Powered's Avatar
Default Re: Re: Evil 3 is the bomb-biggity
Originally posted by MauiBuilt Racer
Howzit goin R!!
JM
Just Wondering. I saw you, Difuser, and pete robinson all have Tamiya Racing Factory or Team Tamiya or something like that in your guys' signiture. Did you all got offered sponsorship deal with Tamiya? Man that gotta be Awsome!
TRF-Powered is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
