Old 02-26-2003, 10:22 AM   #1066
Glitching I thought it was 5 min brain fade you must me getting old if it's coming on at 1 lap now
haha
D
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 02-26-2003, 10:39 AM   #1067
Mark try 2 things with the front gear case
Replace the three 3x8mm screws with 3x12 and also add .1-.3mm shim between the crown and bearing to help tighten the lash
Peter is running no shim and needed a real good board tap to get the clicks I was running .3 and a light tap did it.
The main cause of failure is a board tap on high traction since most are running indoors or for those goldenchildren(Rod and Madjack) who live in SoCal then jumping the curbs at Tamiya America. It seems to be a freespin with a solid landing putting a big shock load through the drivetrain
D
Old 02-26-2003, 11:19 AM   #1068
rtypec's Avatar
Default Damage...bring forth the big hurt!
Damage report: Well, let's see...
The 414M2 suffered a broken chassis and suspension blocks when the screws tore through and out the rear end of the chassis. The rear toe block is bent and I'm missing a bunch of those magical shims. This is from a rear impact (plowing) by another car. Prior to this, I replaced the rear shock tower, diff halves, front rear block, and center oneway from a major shunt into a pole when the shock tower collapsed exiting a 180 causing the car to hook into the aluminum bat...errr pole. Lessons learned, give up on a high roll center setup and try to be quick with the suspension blocks as close to the chassis as possible. Two sets of new tires/wheels bent and mangled.
The Evo3 suffered a little bit less damage. The inner camber link screws (Ti) are bent on one side. One bent aluminum universal shaft, drivetrain REALLY clicking. The salvaged set of tires from the 414M2's fiasco are completely warped/cracked. And a bruised ego
Also, I vented a brand new set of really good UMH cells in my second qualifier.
Dan, I've been mostly cured from the 5 minute standing comas, however, there have been a few times when everything kinda feels foreign to me. You know you're up on the stand, and you begin the think to yourself: Is this how I hold my radio? Is this my radio? Why does my steering wheel feel so squishy and soft? Why does it feel like there's a 4 second lag between me and my car? Is this my car? Why can't i maintain a race line, why does my head feel so light? Why is everything getting fuzzy? Doh! I'm in a coma again!
rtypec is offline   Reply With Quote
Old 02-26-2003, 11:25 AM   #1069
Thumbs up
rtypec,
Most people call that a stroke.
Potato is offline   Reply With Quote
Old 02-26-2003, 11:38 AM   #1070
izzyracer's Avatar
Trader Rating: 27 (100%+)
My knees lock up when I'm in the stand, and my eyes start to flicker, my jaws seem to lock up too...what do you call that? a 5 minute seizure?
izzyracer is offline   Reply With Quote
Old 02-26-2003, 11:45 AM   #1071
rayhuang's Avatar
Default Spur gears!!
Will the RW spur gearsfit and also will a 100 tooth spur fit? With a small modification of the top plate-can you make a 100 tooth fit?
Old 02-26-2003, 11:49 AM   #1072
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
you can run 108 with that small modification to the top plate. thats what I use is 108 tooth spur
weaponx is offline   Reply With Quote
Old 02-26-2003, 11:57 AM   #1073
rayhuang's Avatar
WeaponX-thanks!!! I needed some spare spurs gears for my TC3-so I thought I'd get some for my EVO as well!!! The kit ones for some reason look ....well not that good.
Old 02-26-2003, 12:25 PM   #1074
I have not used the RW spur gears but I dont see why they would not work. 108 tooth spur is the largest spur you can use with out the gear extending below the chassis.
Old 02-26-2003, 02:09 PM   #1075
izzyracer's Avatar
Another win for the TB EVO 3 at the Thailand International Touring Car Championship lead by SURIKARN CHAIDEJSURIYA
Follow this link for more info in Japanese...yikes!
http://www.tamiya.com/japan/rc/thailand/index.htm
Old 02-26-2003, 02:49 PM   #1076
Default Transponder Mount
Hi guys,
Is there a transponder mount available from Tamiya for the TB EvoIII?
I need a part#.
Yokio is offline   Reply With Quote
Old 02-26-2003, 02:53 PM   #1077
izzyracer's Avatar
Default Re: Transponder Mount
Originally posted by Yokio
Hi guys,
I need a part#.
You can probably use one from the TA04 or 414M series or punch a hole on your car body.
Old 02-26-2003, 04:19 PM   #1078
Wilfred's Avatar
Now that Team TRF are using evo3s, Hope they allow 414m2s to compete in TCS, or ban the evo3 on the TCS.
Wilfred is offline   Reply With Quote
Old 02-26-2003, 04:23 PM   #1079
KINGZJ's Avatar
Send a message via AIM to KINGZJ
here in the U.S. they do allow the m2's to compete in the tcs races infact one just won the tcs race at my local track..........
KINGZJ is offline   Reply With Quote
Old 02-26-2003, 04:33 PM   #1080
Wilfred's Avatar
Here in the Philippines they don't. Don't know why, they say its marketing strategy????? Donnu now that TRF drivers are using evo3s.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
