Old 02-09-2003, 11:01 PM   #781
Diva's Avatar
Send a message via Yahoo to Diva
Default Kai Conversion Kit
Anybody would like to get the Kai Graphite Kit for EVOIII? Drop me a pm to discuss.
Diva is offline   Reply With Quote
Old 02-09-2003, 11:49 PM   #782
Cat
Wow, you make your own Graphite Kit ?
Cat is offline   Reply With Quote
Old 02-10-2003, 12:17 AM   #783
Diva's Avatar
No. It's from K Models
Old 02-10-2003, 01:28 AM   #784
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
FoamPervert : Dude, you can put almost any respectable RC car in Nicholas Lee's hands and he will make us mere mortals look bad :P I presume the other Evo3 in the A mains on Sunday in CCK was Ray Lan? How did he finish?
Heheheh dude, you blame ur skills???? heheheheh time to lay off the Starbucks Double Expresso, that stuff makes ur hands twitch heheheheh.
Cheers
NightKidZ is offline   Reply With Quote
Old 02-10-2003, 03:34 AM   #785
Daf
Itchy,
Thanks for the compliments on the TL01 - yeah it did go OK except for the collapsing of the internal droop limiters which made the car go "off" in the second heat (It had 15mm droop at the end of the race!) .
But I did get the Evo 3 on pole on the first meeting out (yes I was running two cars in the one class!) , and that's a really nice feeling especially against the level of competition having two different cars in the A.
The Evo 3 seemed to go really well on the kit set up - all I had done was put the 2mm spacers under the rear suspension mounts. When it gets hot and grippy I am thinking of giving David Jun's carpet setup a try - nothing to loose.
Daf
Metro Hobbies Racing
Model Racing Technoogies
Team Orbital
Daf is offline   Reply With Quote
Old 02-10-2003, 06:56 AM   #786
Trader Rating: 24 (100%+)
Thanks Fangio and rtypec,
Glad to know there were other circumstances behind Tamiya not being at the Birds'. Truly unfortunate that they had no presence....as I said,the rumours and snide comments were in abundance. I hope the bugs are being worked out and the TRF guy's have an oppurtunity to prove themselves.
I've been hesitating to buy the 3 because of these diff problems. Has anybody heard something definite about a FACTORY fix?? Is anybody running a 3 in TCS with the aftermarket diff pieces?? Thanks, Dino
Evoracer is offline   Reply With Quote
Old 02-10-2003, 07:20 AM   #787
Default evo 3 up and running
Hey guys I just got my evo3 together and I am about to do some extensive testing. I did put two runs on it with a stock motor and b2 tires on carpet, and even with the b2's if felt the car handled pretty well. I am not a fan of one ways on shaft cars, but I must say that it wasnt that bad. The car had a little to much push for my liking, but I think tires will remedy this minor problem. As for speed I had no problem at all with straight away speed, I was running a monster stock with 96/37. The car was fast and run time was awsome, still going to play with gearing variables to see were the limit is. The one thing that I noticed about the kit was the quality of the bearings. The m2 has a way better quality of bearings. I soaked them in lacquer thinner and oiled them up with airtool oil and they got a little better, but I think I will replace them with better grade bearings.
mrodney is offline   Reply With Quote
Old 02-10-2003, 07:51 AM   #788
rayhuang's Avatar
mrodney-I assume you rolled out a 1.09" by your info. Cool. I should have my Evo3 back in about 3 weeks or so and I'll keep testing. I am really excited to try it on asphalt w/ rubber tires and foam tires. I bet it'll be unstoppable.
Old 02-10-2003, 07:56 AM   #789
ray. right now I am only going to run rubber tires on the car so that I can prepare for the tcs race in wisconsin in a couple of weeks, and after that I will try the foams, I am not in the mood to chase setups between foam and rubber before this race. I still need to experiment with gearing and mod motors so that will be the focus of my testing. I am planning on going up to larry's after work today to do some testing. By the way, did you end up getting an extra front diff for the car and were did you get the parts from.
Old 02-10-2003, 08:10 AM   #790
rayhuang's Avatar
Default SpeedtechRC
I suspended all spending on the car so no I havent bought the diff yet-though I will need to!!! I contacted Steve at SpeedtechRC and he has all the parts you need. You need to piece it together from F201, TA04 and EVO3 parts-but its all in stock.
Old 02-10-2003, 08:14 AM   #791
THANKS.
I have an f201 as well and was wondering if the diff halfs were the same if so then I have the parts to make up a diff.
Old 02-10-2003, 08:14 AM   #792
rc-zombies's Avatar
can you get the TC3 option parts as well?
Old 02-10-2003, 08:24 AM   #793
Trader Rating: 28 (100%+)
Default 96/37 for monster mrodney ?
You are overgeared!It will be fast but not the punch you should expect.Try 96 33/34 and watch the motor come alive.What your geared at is like starting you car in 2nd/3rd gear.You will eventually burn it up.I have run my evo3 for a month and a half with this motor on rubber/carpet and this is where you wanna gear it.Try it,you will love it.By the way guys,these tamiya bearings suck so bad.Replace them if you just bought the car and if you can afford it. This is my only disappointment.Front spur I can live with.
racenut123 is offline   Reply With Quote
Old 02-10-2003, 08:24 AM   #794
Mark the diff halves are different but the rest is reuseable they are a bit longer than the F201. So the 1-way will not work in the F201 either , bummer
Dan
Difuser is offline   Reply With Quote
Old 02-10-2003, 08:41 AM   #795
hey racenut I ran this gearing in the car for a few runs and the motor was not hot, I ran for about six or seven minutes and acceleration seemed pretty good. All things depend on the track layout. The track I was on was a smooth and flowing layout so bottom end wasn't as important than smooth entry and exit. I used to run a modified tbo1 and am still running an m2 and I can tell you that gearing 96/34 at our track doesnt seem to come close to being competitive. Heck on day a guy with a tc3 ran a 104/39 and just smoked us all. We thought he had a mod motor in that thing but he was running a monster. Now I am not suggesting people go on gear this way, because this guy was a factory driver and could afford to burn up motors,because he has plenty to play around with, but this gives you an idea of what some of the guys in the midwest areas are running.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
