Old 10-15-2011, 08:07 PM   #7186
hi all..
just got a old evo 3 and need some help. looking for some shocks. Will the Tamiya 42102 work on the evo 3??
http://www.tamiyausa.com/product/ite...oduct-id=42102
also, looking for a spool diff.. i have a one way in the front and wanted to try a spool.
thanks..
Losi SCTe
Tamiya Evo IV
bustanut666 is offline   Reply With Quote
Old 10-15-2011, 09:04 PM   #7187
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Originally Posted by bustanut666 View Post
hi all..
thanks..
if it fits Tb-02 then it will fit the Evo3 as well. great car
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 10-18-2011, 09:38 AM   #7188
WC
WC's Avatar
Trader Rating: 28 (100%+)
yes 42102 is right size TRF for touringcar
EvoIII came before the spool era, we ran oneways back then.
You can use balldiff parts without the balls to build a spool.
Alternately you can get a TBe5/TB03 spool which can be made to fit TBeIII.
Put a TBevoIII oneway gear onto this spool axle and you need to make the
whole unit a tiny bit narrower... lose about 0.5-1.0mm is needed.
(Measure width of diff vs spool to guage how much narrower you need)
I filed out the outdrives' pin holes so they can sit further in on the axle.
Don't listen to anyone who says its a drop-in fit... only with a big hammer
Then you'll be wondering why your 1510 bearings keep failing under the sideways stress.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-18-2011, 09:42 AM   #7189
thanks for the information..greatly appreciated.. wish someone sold a drop in spool for the evo3... guess i'll have to try to build one...
Losi SCTe
Tamiya Evo IV
Old 10-18-2011, 09:56 AM   #7190
WC
WC's Avatar
Spools don't work too well on eIII btw... this car predates "crazy power
brushless" and we raced it with brushed motors where oneways were faster.
Try it with a 2nd balldiff maybe, it might be better than a spool.
Only reason i put spool in mine is because it went in the rear
yeah all my eIII fleet are retired to display & drift duty
www.PandaGFX.com
www.MelbRC.org
Old 10-18-2011, 10:00 AM   #7191
i am actually trying to piece together a balldiff now, very difficult because i'll have to get it from probably 4 diff websites... hey, since yours is a shelf queen, wanna gut it and sell me a balldiff or a spool?? hahaha.. PLEASE....
Losi SCTe
Tamiya Evo IV
Old 10-18-2011, 10:08 AM   #7192
WC
WC's Avatar
heh i love the eIII... they worked well for me, took it to TCS
Did sell off some cars but still got fair fleet left in all 3 colours
plus a red kit autographed by Surikarn whilst he was World Champ
shouldn't be too hard to piece together a balldiff,
most parts are common bits except for diff outdrives
eIII outdrives
eIII balldiff gear
2x 850 BBs
M2x25 diff screw & nut (u can even use yokomo or 3Racing parts)
thrust bearing ( "" )
spring
diff rings... i think they're F201
3mm balls (not needed for spool)
Cut some cardboard same size as diffrings for spacer between diffrings & the gear.
if u can, buy the BLACK outdrives (from TBeIII) which are
cheaper & less brittle than the white TBeIIISE ones
avoid buying TB02 diff outdrives unless you have really no alternative,
the eIII parts were unable to find few yrs back but have since reappeared
Spool mod here if you need http://melbrc.org/vB/showthread.php?t=4376
www.PandaGFX.com
www.MelbRC.org
Old 10-18-2011, 10:13 AM   #7193
eIII outdrives
eIII balldiff gear
2x 850 BBs
spring
thanks.. that link is awesome.. exactly what i needed... think i am going to build a spool and also try to get another balldiff to run in the front... see what i like better...
Losi SCTe
Tamiya Evo IV
Old 10-18-2011, 10:15 AM   #7194
WC
WC's Avatar
found the balldiff 2 spool tute --> http://melbrc.org/vB/showthread.php?t=4530
which part of the globe u hail from matey?
www.PandaGFX.com
www.MelbRC.org
Old 10-18-2011, 10:19 AM   #7195
another great tutorial..thanks.. i am located in California, US...
Losi SCTe
Tamiya Evo IV
Old 10-18-2011, 10:24 AM   #7196
seems like the cheapest way would to buy the TB03D spool and modify it. Because piecing together a balldiff alone is going to be around $50.. too much considering i only paid $100 for the roller..haha..
Losi SCTe
Tamiya Evo IV
Old 10-18-2011, 10:25 AM   #7197
WC
WC's Avatar
btw is this the car you're talking about?
if it is... bad news buddy, that ain't an eIII
Original TBeIII came in green, TBeIII Surikarn Edition was red
and eIII only appeared in blue if you added the blue hopup kit (pic shown earlier up)
Yours looks like a TB Evo IV... i don't think its the later IVms
III, IV & 5...
www.PandaGFX.com
www.MelbRC.org
Old 10-18-2011, 10:33 AM   #7198
III, IV & 5...
damn.. i got scammed... haha... i think it is a evo iv... now that i look at the manual for iv... so the IV is worst than the III... i would think it would be better since its newer...
great... now this messes everything up.. hopefully i'll have better luck shopping for IV parts than III..
Losi SCTe
Tamiya Evo IV
Old 10-18-2011, 10:45 AM   #7199
WC
WC's Avatar
i would't say "bad"... yeah my eIV pictured above didn't really work for me
compared to eIII or e5 so that runner got sold off shortly afterwards
although i still have 1 of 2 NIB kits i bought originally + some parts
but guess what i was doing last week... yep, giving eIV another go
another mangy example landed on my doorstep & i gave it uber TLC...
upgraded diff to alloy TBe5 spec
changed the IV bulkheads to IVms spec, option clear covers
you're in luck, TB03 spool (~$20?) IS NOW A DROP-IN FIT
(however u should change the gear to correct eIV part, TB03 uses e5 gears)
end result:-
now with ltd edn green shaft, also green steering rack borrowed from a TBeIII
www.PandaGFX.com
www.MelbRC.org
Old 10-18-2011, 11:10 AM   #7200
actually i am happy that its a IV now and not eIII. Parts seem to be easier to get, even a local shop has IV parts...
little confused...you mentioned earlier "(however u should change the gear to correct eIV part, TB03 uses e5 gears)"??? isn't the gears already eIV since the car is eIV
Losi SCTe
Tamiya Evo IV
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
