Tamiya TB-Evolution III
#7126
Hey TB Evo 3 Guys; can you Help Me on this?
I would like to know the Length(in Millimeters) of the Evo 3`s Battery Plate.
-I need a battery Plate for My Evo 5.
Take Care
Take Care
#7127
i have a TB-02 and an Evo III. I took everything from the evo and put it on the 02. are there any other hop-ups i should get or what are the best hop-ups for it
#7128
#7130
Just go and buy the TA05 hopup plate, drop-in fit for e5.
#7131
HI GUYS, I'M FROM INDONESIA. I HAVE TB EVO 3 SURIKARN AND I OFTEN STRIPPED MY FRONT BEVEL GEAR WHEN RACING USING MOD MOTOR <=11T, EVEN I DON'T HAD ANY FRONTAL CRASH...IS THERE SOME WAY TO SAVE MY BEVEL GEAR?? PLEASE PM TO ME....
#7132
#7133
it is too short, you should change to the HopUp option EvoIII lightweight shaft
or TB02 shaft, both is 2mm longer. Or best is TechRacing 3-piece shaft.
Longer shaft will reduce bevel stripping as it supports the bevel pinion better.
#7134
The grey EVO III lightweight shaft is not the best one to use - you may still experience problems (I did). The best shaft to use is the blue one as it has fatter bevel ends and is 4mm longer then the original Evo III shaft and 2mm longer then the gery light weight one. Part # 49369 (how many revisions do Tamiya need? 4mm is not excatly a small error )
And as buboy28 said get the alloy - its a must
#7135
Talk about resurrecting an old thread.
Just about to buy the Evo IV Aluminum ring gear to get my evo going again and hopefully cure the one way problem. Then I need a new shell and get down a proper setup.
#7136
After looking at the Evolution IV manual and examining my Evo III, I think the propeller shaft and cups may be interchangeable onto the Evo III, all thats needed is to exchange the motor mount bearing for the transmission case one and vice versa, use the Evo IV bevel gears and wala.
#7139
I summon you, Evo the III! Come back to life and win me some races!
#7140
resurrecting my EVO-III (alas poor evo i knew you well)
Sorry to resurrect such an old thread, but I just got back into rc and I pulled my old EVO-III surikarn limited edition off the shelf. Still runs fast , but still has the same problem i always had - pull the trigger and it takes off, but it sounds awful like the diffs are chewing themselves apart. I am afraid to take it apart, but I will, just don't want to look at what has happened to the gears. Is there somewhere I can buy new diff assemblies for the Evo-III, tower doesn't seem to have any and I can't find them at Stormer Hobbies. I KNOW I'm gonna need them, do the diff assemblies from the EVO-IV and V fit into it??? This car is great and needs help, i can't just let it sit around, its fast and furious. I have the one way diff inthe front and think I want to get rid of that. Any suggestions would be helpful
Thanks,
Rich
Thanks,
Rich
