Old 02-24-2006, 02:51 AM   #7096
thecrow2k's Avatar
Bubbles, been trying that, I have the tb-02 lw shaft, xenon gears and yokomo shims and its not helping. I may be runing the car tomorow if my B4 cant run but yes, this car is capable of winning. Im a poor driver and I won the B Final at our club. 6 Months ago it wont the stock A final at our club.
thecrow2k is offline   Reply With Quote
Old 02-24-2006, 03:46 AM   #7097
Hebiki's Avatar
Trader Rating: 26 (100%+)
where are you shimming it exactly?
bubbles.. i think the car is still very capable. but everyone has moved on...
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-24-2006, 05:07 AM   #7098
fat500's Avatar
Trader Rating: 29 (100%+)
car is very capable I just built up a evoIII surkinan in BLUE and am posting the same ,well 1/10 of a sec diff , lap times as my evo4. I went back to the evo 3 ,seems stronger than the 4 and I HATE the small holes on the corners of the evo4. I don't like to rebulid my diffs and we race at a dusty track and the dirt always found its way into the 4's diffs. III is sealed. I ran a tbo2r with great results too. I will stick with my evoIII for a while. My tao5 ran great too but same broblem with the diffs.
Thanks to turbo joe foir the evoIII parts hookup.
and......all else who got me the goodies....
fat500 is offline   Reply With Quote
Old 02-24-2006, 09:17 AM   #7099
bubbles's Avatar
I don't know, because I've never tried xenon gears...
I run a TC3 front One-Way gear in my EVO III and have very few problems. Yes, I know it changes the roll out of the car. TC3 has 40/16 gears, and the EVO III has 39/15...
Front = 2.66:1
Rear = 2.60:1
I wish I could say that I felt something bad about the changed ratio, but it feels the same...
You could try some Pro4 gears... it's a tall ratio of 39/16... or the Barracuda R2's with their 39/16(if I remember correctly).
CHRIS LIM!
What's up?
What're you running now days?
The reason why I asked if the car was still capable, was because I've noticed that everyone seems to be dropping over $400 now days on either the Xray, or the 415MSX Refined, or the Corally, or the Hotbodies Cyclone. (I havn't raced in over a year) At first I was like, "Oh snaps, now I'm NEVER going to be able to compete." So I put my car on the track with my old EPIC zebra cells, and $10 Green Machine 3, and attempted to do laps...
I pulled a 10.0 laptime with the Green Machine 3, and broke into the 9's with a Monster Motor on Tuesday, but chose not to race...
Turns out that low 10's and high 9's was the pace for Stock.
bubbles is offline   Reply With Quote
Old 02-24-2006, 09:37 AM   #7100
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
No problem...lemme know when you want the pretty red one.
Turbo Joe is offline   Reply With Quote
Old 02-24-2006, 11:04 AM   #7101
Hebiki's Avatar
Front = 2.66:1
Rear = 2.60:1
CHRIS LIM!
What's up?
bubbles!!! whats up playa pimp! good to see you coming back to your roots! the question should be.. what havent i RUN? ive tried them all.. they're fun. i guess i was addicted to building cars for a while there. i have a T2 now..and my Tamiya TA05. will probably go back to Tamiya and get an MSX. or evoIV. btw.. you will be able to keep up with your evoIII..with new batteries.. you'll find yourself winning too
as for the evoIII.. the reason i ask where you shim it is.. its key. to remove the fore/aft play.. using the new TB-02R shaft will remove most of it... then you need to put a shim between the end of the shaft and bevel gear.
i also found if you tighten down the gearbox..it'll pinch the diff or oneway..so i put spacer inbetween those.
wish rod canare would jump in here.. he had the evoIII mastered down to a science. won some race called the Reedy Race of Champs or something. then went to japan...
edit: makes me wanna go out and get one now just for kicks..and try it with the lightweight suspension.
Hebiki Design Works
Old 02-24-2006, 01:48 PM   #7102
bubbles's Avatar
I didn't always like Rod's solution...
Try not to crash.
Hahahahaha.
Old 02-24-2006, 04:07 PM   #7103
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
bubbles, SELL IT, to slow
u know I'm kidding, bubbles has not lost any speed the guy is still fricken fast.
King of B Main is offline   Reply With Quote
Old 02-27-2006, 02:34 PM   #7104
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default help
what is the best gearings for tbevo3 surikarn when im using tamiya superstock TZ?????? best gearing... top speed and good acceleration..
nikkiesteban is offline   Reply With Quote
Old 02-28-2006, 12:39 AM   #7105
bubbles's Avatar
As like, an educated guess, I'd start around 7 and go from there... Taller or shorter ratios depending on how it feels.
Chris Lim:
Where should I look to for batteries? If new packs could pull a tenth or two off my times, I'd like, hug the batteries.
Haha.
Old 03-13-2006, 05:07 AM   #7106
fat500's Avatar
ok, i noticed several guy,s running the A,B,C,D suspension mounts from the evo III on their ta05,s. Someone said the mounts on the evo 3 , 4 , and 414-415 are all interchangeable. Is the geometry different or are they drop ins?
I would like to confirm this. Looking at them they look like they would fit. The evo 3 to ta05 i can confirm cause i looked at the car. Thanks guys.
i should have kept my 05
Old 03-13-2006, 05:31 AM   #7107
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
The mounts from the EVO 3 will fit the TA05 but are 1mm taller. YOu will still need the Bridge mounts for the inner part of the chasis since they go over the belts. If you use the EVO 3 mounts you will need to use 1mm shims under the bridge mounts. The 415 and TA05 mounts all have a 1 after the letter (A1, B1, C1 etc). Other than that they are interchangable.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M06|F104 Pro|F103RM|RM-01
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 03-14-2006, 05:26 AM   #7108
fat500's Avatar
thanks f-1 larry. Anyone else have any experience?
Old 03-20-2006, 08:24 AM   #7109
Does anyone know the F201 bevel pinion gear is suitable for TBevo3 or TB02?
G2B Anthony is offline   Reply With Quote
Old 05-02-2006, 04:04 PM   #7110
Send a message via MSN to Cesar Ramos
I happen to have a evo3 and a ta05. last night I moved my hard suspension set from my [evo] to the [ta]; which included moving the suspension mounts.
suspension mounts
I noticed that for the 415mx they inverted/flipped over the inner mount and put a single 3x3mm spacer underneath it. But note the mounts for the 415mx and the evo3 have different part #'s.
so i did the same thing...
I got an A for the inner and an A for the outer. For me get the holes leveled i had to put 3-3x2mm spacers underneath the inverted mount. (I used 3x2mm spacers cuz it's the only thing i had). You also have to use a longer machine-type screw.
suspension shaft
use the ta05 shaft, the evo3 is longer (by how much? don't know) also use different spacers.
swing shaft
I'm also using the universal shaft assembly off of the evo3; it's a little short, the ta05 (53836) uses a 48mm. I find out soon if it pops out.
so...the belt clearance is there and it works.
I'm moving the back ones tonight (5/2/2006)
Cesar Ramos is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
