Old 12-14-2005, 10:31 PM   #7081
Sushi Man's Avatar
Send a message via AIM to Sushi Man
k i am hella confused... i got shims (.1mm) and i put 2 in on the side that pushes towards the bevel gear (right) and i have none on the other side. when i put the gear boxes together i hear a weird binding noise and the tires dont hav emuch free spin... i need help/
Sushi Man is offline   Reply With Quote
Old 12-14-2005, 10:44 PM   #7082
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Shim the one-way FIRST...so that you have just a tiny amount of play side-to-side...without the crown gear in the case.
Put the crown gear (the little one) in the case, then the one-way.
Move the shims from side to side until you have very little lash (free play) between the one-way and the crown gear.
Both boxes, shaft and spur holder must be in place and assembled to check the lash, because the shaft holds the crown gear in place.
I don't run any shims on the crown gear. Even one will make it jam into the one-way gear and bind.
Turbo Joe is offline   Reply With Quote
Old 12-14-2005, 11:43 PM   #7083
Sushi Man's Avatar
well wouldnt u need to shim the box to get the least amount (logically thinking) also i dont get the point of shimming the one way before i put the crown gear (bevel gear) in... Dont i have to reshim it later anyways>>??? thats for the reply i got some of it.
Old 12-15-2005, 02:15 AM   #7084
Turbo Joe's Avatar
Because you can't really tell how tight you have it with both gears...if you do the one-way by itself, then you have the total number of shims already, you just move them around ot get the lash right.
It always seemed to me that if I tried to shim the crown gear "deeper" that it bound up immediately. The only way to know for sure is to try it, but I never had one that needed to be shimmed deeper.
Old 02-04-2006, 03:22 PM   #7085
As far as I know, the Tamiya one works with the newer gear. The Peguin one works with the old gear that nobody uses anymore.
The current EVO-III gear has a big lip around the ouside and the Tamiya plate drops right in perfectly. I think the Penguin plate is larger on the OD, so you can only use it on the old flat gears or the Xenon or Tc3 Gear.
Our P2705 EVO-III gear adaptor is counterbored to support the gear from the center all the way out to the outer lip, The plate is the entire diameter of the gear. This is why the gear is supported enough to eliminate all stripping caused by gear flex which is the main cause of the EVOIII gear problems.
Thank you,
Penguin r/c is offline   Reply With Quote
Old 02-05-2006, 06:48 AM   #7086
thecrow2k's Avatar
I used the xenon one way gears, biggest piece of crap ever, unlike the tamiya plastic oens which gradually wore the teeth down. The xenon gears just have the teeth rip straight off. Terrible, getting very annoyed with the evo now.
thecrow2k is offline   Reply With Quote
Old 02-05-2006, 07:08 AM   #7087
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
All you need is the EVO IV Aluminum one way gear, have had it a year now with no problems Part #53721
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|Associated B5M|TA05|TL01RA|TL01|F104 Pro|RM-01
f1larry is offline   Reply With Quote
Old 02-05-2006, 12:54 PM   #7088
thecrow2k's Avatar
Well I may get that eventually, for now Ill have to cope
Old 02-12-2006, 08:15 AM   #7089
fat500's Avatar
Trader Rating: 29 (100%+)
Default need part....
hey guys, i am in need of the blue alum. center supports for the evo3 .
if any one has them for sale pm me. tried ebay and speedtech,no luck. thanks, marc
i know square made a set saw it on speedtecs web site
fat500 is offline   Reply With Quote
Old 02-12-2006, 08:39 AM   #7090
moshmike's Avatar
http://www.besthobbysite.com/shop/in...p?cPath=82_104
Check here! Not sure what shipping is though!
Mike
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 02-12-2006, 10:14 AM   #7091
Turbo Joe's Avatar
Marc:
I PM'd you earlier...but FYI for the rest of you guys...you can use the EVO-IV MS center support. There's also Xenon one for the IV on there (@ speedtechrc.com)...they both use the same "J" parts (battery mounts/brackets). I have one in my blue-kitted "III".
Old 02-12-2006, 10:43 AM   #7092
fat500's Avatar
still no luck on the center posts, thanks for the tip on the evo4 one.
i will wait a day or so to see if the square ones pop up.
Old 02-12-2006, 10:57 AM   #7093
hierog's Avatar
i think i have 3 of the Xenon blue supports. I'll sell them to you for $15 shipped if you want em
let me know
vic
hierog is offline   Reply With Quote
Old 02-12-2006, 04:41 PM   #7094
fat500's Avatar
i will take-em
Old 02-24-2006, 12:09 AM   #7095
bubbles's Avatar
Run the longer shaft, updated One-Way gear, and shim it correctly and you shouldn't have problems...
And just out of curiosity...
Has anyone had recent success with this chassis? Or has everyone "moved on"?
bubbles is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
