Old 12-10-2005, 04:01 PM   #7066
thecrow2k's Avatar
Just bought 3 xenon gears so could be good. Are the xenon gears weaker not having the lip?
I thought they were stronger, thats why I bought them.
thecrow2k is offline   Reply With Quote
Old 12-10-2005, 06:12 PM   #7067
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I "hear" they're stronger...but I have no experience with them.
Turbo Joe is offline   Reply With Quote
Old 12-10-2005, 07:53 PM   #7068
Sushi Man's Avatar
Send a message via AIM to Sushi Man
hey turbo joe wanna sell some of those one way gears??? also i am confused like Crow. with shimming.. i have the bevel gear shimmed (so it pushes further into the gear box and one way) and i have one thin shim on oneway so it pushes towards the bevel, BUT i only have one, and thats all that fits, is this right?
Sushi Man is offline   Reply With Quote
Old 12-10-2005, 11:10 PM   #7069
Turbo Joe's Avatar
As I recall, I think I have a thick and a thin Tamiya one on the one-way and none on the bevel gear. You can't really move the bevel gear in too much or it will bind bad.
The LW shaft or the later TB-02R shaft is a little longer and they hold the bevel a little "steadier". It's kinda hard to explain, but the shaft is a BIG part of the system, since there's only one bearing on each end...other shaft cars have two in each gearbox.
I wouldn't even put any shims on the bevel. The only way you can really know if it needed them there is to partially assemble the car (both gearboxes, upper deck, spur assembly, motor mount) and check to see if it's binding...add shims until it binds, then remove one. Mine's perfect w/o shims on the bevel gear.
I think I have a couple of one-way gears left...you can't get them locally? I usually get mine from Speedtechrc.com or at SoCal. If you're in a bind, I'm sure I can send you some, but you should be able to get them...PM me if you need some...
Old 12-11-2005, 12:16 AM   #7070
Sushi Man's Avatar
weird I could Only FIt ONE thin one on the side that pushes towards the bevel gear.
My gears still strip REALY REALLY easy, small crashes, I mean they still rip em out.... what can I do... I have the LW TB-02r shaft... so thats okay! right?
DO TC3 one way gears FIT!!????
Old 12-11-2005, 12:54 AM   #7071
Turbo Joe's Avatar
You might want to get another gearbox. They get smashed around and it messes with the clearances.
Supposedly...the TC3 gear will fit...never tried it, but it looks really close.
Old 12-11-2005, 01:03 AM   #7072
Sushi Man's Avatar
r u sure? i wouldnt want to waste 10 bucks... Also the Xenon gears do help, I noticed that the gear that the car came with was a Xenon gear (when I bought it) and it lasted the the longest out of all my gears (gone through 4 ) and it wasnt even shimmed.!
Old 12-11-2005, 01:56 AM   #7073
Turbo Joe's Avatar
They're only 7-8 bucks...at least around here. Mine was pretty loose and I had to re-shim it whenI got a new one. I originally replaced it because the screws were stripped, then I noticed how much it changed the gear setup.
Like I said...I heard the Xenon was better, but I never tried it.
Old 12-11-2005, 03:41 AM   #7074
thecrow2k's Avatar
Good to hear the xenon gears are stronger.
I really wanted the tech 3 piece shaft as there was one for sale but its sold.
I hope having the xenon gears, the lightweight shaft and shimming will help. I may buy the penguin backing plate is, if I stil strip a xenon gear, Ill buy the penguin plate or see if anyone is selling the jurgen oneway, does Jurgen still make them?
Old 12-11-2005, 12:03 PM   #7075
Sushi Man's Avatar
idk.. so i should replace the gearbox.. dang.. well if I strip it again -- im going to the evo 4 alloy gear man! save me the time and money!
Old 12-11-2005, 01:04 PM   #7076
Sushi Man's Avatar
Okay I was Able to fit two thin ones to push towards the bevel..
Now I woont strip any right?!!!!
Old 12-11-2005, 01:31 PM   #7077
thecrow2k's Avatar
You'll strip if you hit too much but it should prevent it. Im hoping my stuff will cure the stripping 99.9%.
Old 12-11-2005, 01:47 PM   #7078
Sushi Man's Avatar
crow it wont be 99.9 Percent... it will strip if u hit hard once probaly.. I just want to not strip from slight crashes... I think the alloy gear might be the best solution
Old 12-11-2005, 03:58 PM   #7079
Has anyone found that when putting using the battery holder and posts on the evo 3 causes the bottom chassis to be tweaked ?
I think the battery posts need to be filed down so that batterys can fit better or might have to go to tape.
Phenochilus is offline   Reply With Quote
Old 12-11-2005, 05:04 PM   #7080
Sushi Man's Avatar
I already use tape, Its actually not that annoying.. frankly its faster than using pins (my opinion)
I was actually able to fit three .1mm 10mm shims in the onegear... Four was a little two much! I hope this works, about to go to the LHS to buy some one way gears.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
