Tamiya TB-Evolution III
#6961
Originally Posted by junn
Howzit
This is my first post on this forum
I have an Evo 3, i lost both bottom screws to the knuckles. I have decided to get some aluminium ones. But, I havent found evo 3 knuckles, only evo 4, or evo 1 and 2. Does anyone know where which of the above will fit?
Also, on the subject of gearing, I will be running my evo in the stock silver can class, what gearing would you guys suggest? another gear in our club is using the 72 tooth spur with 46 tooth pinion, 64 pitch.
Can anyone please help
thanks
thanks
#6962
72/46 will work well on a long track but will run hot as if you have a technical infield.
You may want to have a selection of pinions 44-47T
The evo3 is a fast car in silver can motor grades.
#6964
newb needs help!!!
my evo3 recently started to "chick" in the rear diff i think it is going to break!!!! what should i do??? i still have the standard propeller shaft but have upgraded my front one-way with a metal gear, i do not know what to do
tnx for any reply
tnx for any reply
#6965
The metal gear in the front will make lots of noise however shimming the back gearbox can help with that "chick" The metal gear in the front proably wont help things though and im wondering where on earth did you get that??? Make sure theres not flat spots on any of the 4 gears ( 2 bevels and 2 ring gears) and then you should be fine. The option shaft is worth the money as well when you have a chance to find it.
#6967
Shimming
Ok - This may sound like a dumb question but how is the best way to shim the gearbox ? I just started racing the stock class at my local track but my car is a little off the pace. All the fast guys say I need to free up the drive train. I'm using all the drivetrain out of a TB 02 with the lightweight drive shaft. BTW I'm running a diff front and rear. This car is still competitive against the Pro 4's and TC4's I just need a little more speed !!!
#6968
The metal gear is a tbevo4 alloy oneway gear, it works well, I havent broken my fr gearbox since fitting this part.
#6969
speedtech has them
Originally Posted by bigtez
does anyone know if there is a spool available for an evo3? whats the part no.
#6970
Evo 3
Is anybody selling an Evo 3?
#6972
Email me if you have any questions...
#6973
Since the Evo III and IV share the same one-way I would think the spool for the Evo IV (49359) would work. The package does not say Evo III though ...........any thoughts?
#6975
There are 2 screws in my top deck that have been rounded off, with one i sanded into it to try and be able to take it out with a flat head driver but that never worked and I cannot take the top deck off and if i sand the 2 screws down and slide the top deck off, I have deck mounts in red aluminium that are uselessm, any way to get the screws out?
