Old 03-24-2005, 04:24 AM   #6886
fire929's Avatar
Default Gearing
I use a 42, 43, 44, tooth pinion 96 spur for 540 silver can and my evo III is very very fast.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 03-24-2005, 04:32 AM   #6887
fire929's Avatar
Default 540 stock
I use a 36-38 tooth pinion on a 96 pinion you can use this to determine what pinion range you should start with pinion size = rollout ex 40mm x driv ratio ex 2.4 for pro 4 x spur size /197.9208
equation would be 40mmx2.6x96/197.9208 50 tooth to get a rollout of 40mm but stock motor may not run real good like this might not be able to use the full rpm curve.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 03-24-2005, 07:09 AM   #6888
thecrow2k's Avatar
Hey guys, will be getting my surikarn evo III in a couple weeks and am gettign very worried about this gear stripping, I own a TT-01 so never had to deal with one ways and shimming and dont even know what shimming is, I will be running a Tamiya silver can motor for a while and would be running the one way, will I suffer from stripped gears alot and is there any solution or is it just some people strip the gears and some don't, thanks!
thecrow2k is offline   Reply With Quote
Old 03-25-2005, 09:27 AM   #6889
thecrow2k's Avatar
Anyone
Old 03-25-2005, 10:04 AM   #6890
Read the prior posts on this page on gear stripping. Shimming is just adding or removing spacers between the outdrive bearings and diff to adjust the mesh between the ring and bevel gears. proper mesh is important to minimize gear breakage. There's a new light weight center shaft that's supposed to help too.
DOTMAN is offline   Reply With Quote
Old 03-25-2005, 10:08 AM   #6891
thecrow2k's Avatar
Does using a regular diff up front eleminate the problem
Old 03-25-2005, 10:19 AM   #6892
No. A diff allows some give if you hit something so you're less likely to break but it can still happen. Shimming is still the best thing you can do to avoid breakage
Old 03-25-2005, 10:27 AM   #6893
thecrow2k's Avatar
okay, where should I shim and which side
Old 03-25-2005, 10:59 AM   #6894
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Shim the gear towards the bevel gear (shim behind the bearing) until the lash is almost gone...but not so much that it binds up. It takes some playing around to get it right, but it works REALLy well.
I carry a few gears with me just in case, but I haven't used one in months. They're cheap ($3 or so) and they take 5 minutes to change, so don't lose a bunch of sleep over it.
Turbo Joe is offline   Reply With Quote
Old 03-25-2005, 12:17 PM   #6895
thecrow2k's Avatar
So with whatever shims shim on the side of the bearing which will be facingtowards the wheel
Old 03-25-2005, 01:35 PM   #6896
Turbo Joe's Avatar
With these shims, adjust the play by adding shims between the bearing and the one-way, usually on the same side as the big gear.
Old 03-26-2005, 01:57 AM   #6897
V12
V12's Avatar
Hmm, I never heard of breaking gears using a frontdiff. But usually I used a oneway not a frontdiff. But after switching to the Jürgen oneway I broke just one gear within 1 year of use.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 03-26-2005, 03:38 AM   #6898
thecrow2k's Avatar
Okay cheers, Ill lock for some 10mm shims at my LHS when the car is in my hands in a few weeks, thanks guys
Old 03-27-2005, 01:24 PM   #6899
fire929's Avatar
Default Shims
Where can you buy the shims online for the diffs.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 03-27-2005, 02:49 PM   #6900
Turbo Joe's Avatar
At the link I posted earlier...look a few posts up the page.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
