Old 02-03-2003, 06:27 PM   #676
Trader Rating: 28 (100%+)
Default Spool you said?
Who made the spool for you and HOW can I get one?
racenut123 is offline   Reply With Quote
Old 02-03-2003, 06:48 PM   #677
izzyracer's Avatar
Trader Rating: 27 (100%+)
racenut, concerning tamiya reps. I see this guys on a weekly basis at the TA track, and they are aware of the problem. They are cool guys and are very helpful, you probably just talk to one who did not have his lunch yet. Even David Jun has had experience the front bevel gear stripping and Fred M. has acknowledge the issue and it is something they will address.
izzyracer is offline   Reply With Quote
Old 02-03-2003, 06:52 PM   #678
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
other than the bevel gear this car is an absolute monster it literally eats the track up.
weaponx is offline   Reply With Quote
Old 02-03-2003, 07:31 PM   #679
Weapon I think that is the kit I have also I grabbed some refills off the shelf and didn't realise until I got back that they were the 10MM shims. Sorry no #'s now
The spool I made using(hope it doesn't delete swear words) Losi
diff pads they have the sandpaper insert you use on the front diff plates. CA it onto the ring then CA the ring to the outdrive and voila' spool I didn't CA the ring to the outdrive and it tried to spin the rings on the outdrive so I glued them down.
I do have a friend making them soon and they will available if there is interest out there.Probably alum withe the ability to use the hardened outdrive from the 1-way for durabilityhopefully coming soon.
Tom hurry up ad get settled and get you butt up here to race
D
Difuser is offline   Reply With Quote
Old 02-03-2003, 07:43 PM   #680
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by Difuser
Be sure to use a dry lube on the ring and crown gears to help keep friction down
what do u mean when you say "dry lube"?
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 02-03-2003, 07:57 PM   #681
A greaseless product I use White Lightning brand normally used for bicycle chains. It lubricates but does not attract dirt or in the case of the EVO cause stiction in the gears slowing or binding up the car. With no pinion my car rolls forever right now I have about 5 hours or so trying different lubes in the bearings and gears but it is freeeeeee now.
D
Old 02-03-2003, 08:36 PM   #682
Ray
Ray's Avatar
Send a message via ICQ to Ray
Wink
Hi fellow Evo 3 owners!
Just put my Evo 3 together during the New Year holidays. Have'nt had a chance for shake down runs yet.
I found a good way to prevent dirt from entering the main shaft bearings. Know of reinforcement rings for hole punched paper??? Its got an internal dia. of 6mm, exactly that of the shaft. just stick it at the bearing mounts. CHEAP and most importantly works! Esp for ppl runnning on carpeted surfaces. (a shame that a car of this caliber does not come with Tamiya rubber sealed bearings)
Peace! Rev on!
Ray is offline   Reply With Quote
Old 02-03-2003, 09:00 PM   #683
Fit
Default EVO 3
Hi Ray,
How much did you pay for the EVO3?
And did you get it from Winnie?
Deciding between an 04R and EVO 3...
Thanx
Fit is offline   Reply With Quote
Old 02-03-2003, 09:02 PM   #684
Thumbs down Sorry to say.
But if what your saying is true izzy,then the guy I talked to is a lyer,Plain and simple.He said that David never experienced this problem and he had no knowledge of the problem.So I know he is a liar,not a absent minded track official.He made me out to look stupid in front of others because he could/would notacknowlege the problem with the one way.Oh Well..........................
Old 02-03-2003, 09:05 PM   #685
littledog's Avatar
Damn the luck!!!!!
littledog is offline   Reply With Quote
Old 02-03-2003, 11:14 PM   #686
izzyracer's Avatar
Default Re: Sorry to say.
That's to bad! hopefully you will have a better experience with them next time.
Old 02-04-2003, 12:55 AM   #687
alan1467's Avatar
Tamiya supply a 10mm shim set parts number :-
TAMIYA,500yen ,53588 10mm SHIM SET 10PCS. This is from Rainbow Ten
alan1467 is offline   Reply With Quote
Old 02-04-2003, 10:19 AM   #688
R/C Tech Founder
What are the part numbers for the tuning spring sets for the Evo 3's shocks? I checked Tamiya's site and they have a few different sets, but I am lost as to which is the one to get.
Is there a spring chart anywhere for the car?
Thanks!
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 02-04-2003, 10:40 AM   #689
rtypec's Avatar
futureal, look to get the hard onroad spring set, and if you feel like it, get two of them These are the springs that look darker than the regular springs (the regular ones being all neon colored). The chart for both springs and rollbars is as follows:
Red=Soft
Yellow=Medium Soft
Blue=Medium Hard
White=Hard
They also sell matched spring sets with four identical springs if you're into that.
rtypec is offline   Reply With Quote
Old 02-04-2003, 10:42 AM   #690
rtypec's Avatar
About the front gears in the Tevo3, they've order a buku load of them and should be in at any moment. Also, there may be something in the works to remedy the gear situation.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
