Old 03-19-2005, 02:19 AM   #6856
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Originally posted by C_O_jones
Could anyone tell me the size of the lower steering post spacers, below the steering linkages. Im piecing together an EVOIII without a manual
Thanks, Fred
There are no spacers below the bellcranks ...that's what you're talking about, right? It's just a shaft with a step on it. The spacers are on top.
Do you need a measurement on those?
Turbo Joe is offline   Reply With Quote
Old 03-19-2005, 09:55 AM   #6857
Originally posted by Turbo Joe
I have a BUNCH of extra ones if you need some...or just don't want to buy them. I used to blow out the big gear all the time...so I have some extra bevel gears.
Hey, Joe...yeah I would like to get those from you. I'll PM you my contact info.
Thanks, Man
DOTMAN is offline   Reply With Quote
Old 03-19-2005, 09:59 AM   #6858
Originally posted by jeffreylin
What's up Oliver! I don't think there is any. The best solution I know is just use the longer lightweight shaft. It strips a lot less. Evo4 has this problem too but less. I end up stripping the spur instead.
Hey, Jeffrey...I just bought the lightweight shaft (too bad they don't come in blue). I'm in the process of rebuilding the EVO3 and I noticed that both my bevel gears were thrashed and surprisingly, my ring gears were fine. When I went to look for spares, I found that I had a bunch of extra ring gears but no bevel gears. I'm sure the new shaft will help, but right now I need some replacements.
How's the EVO 4 running? Have you been racing lately?
Old 03-19-2005, 12:14 PM   #6859
jeffreylin's Avatar
R/C Tech Charter Subscriber
Been racing mostly nitro. Haven't run my electric cars for a couple of months now.
I had the same problem with the Evo3. My ring gears never had any problem but the bevel gears keep breaking. The new shaft will help but you should still check them if you have a big crash, especially the front one.
jeffreylin is offline   Reply With Quote
Old 03-21-2005, 03:07 PM   #6860
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
what the best method to clean out your front one ways that come standard with the tb evolution 3. As far as i can see you cant open it so do you give it a spray of motor spray or bearing lube or something??
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 03-21-2005, 08:21 PM   #6861
Charlie O's Avatar
Yeah! spray it out with motor spray, then follow with a Q-tip, then put some bearing oil on a Q-tip & run it through again.
Charlie O is offline   Reply With Quote
Old 03-22-2005, 02:32 AM   #6862
DJB
DJB's Avatar
Whats a Q tip??
Old 03-22-2005, 02:50 AM   #6863
jeffreylin's Avatar
Originally posted by DJB
Whats a Q tip??
cotton tips
Old 03-22-2005, 03:27 AM   #6864
DJB
DJB's Avatar
thanks man
Old 03-22-2005, 09:32 AM   #6865
V12
V12's Avatar
Hmm, motor spray on the oneway bearings? From what I know this isnīt a good idea. Motor spray may damage the inner plastic of the oneways cage.
I just use Serpent oneway lube on all of my cars and thatīs it.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 03-22-2005, 11:42 AM   #6866
Charlie O's Avatar
I havn't had any problems with motor spray on any type of plastic, now if you take some carbeurator cleaner to the same part, and it will melt it! most plastics dont get along with carb cleaner.
Old 03-22-2005, 04:29 PM   #6867
fire929's Avatar
Default Hey Guys
Have a evo III deal pending and I see alot of talk about the drivetrain ring gear and or bevel gear. Is this something that would make you buy the evo IV or is this problem able to be corrected. please advise!!!!!!!!!!!
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 03-22-2005, 04:49 PM   #6868
Actually I hear the evo4 has the same problem but to a lesser degree. From my experience, shimming is the best way to reduce gear breakage. If you spend some time with the front diff (particularly if you run a spool) and get it shimmed right. It should work pretty well for you in most cases.
Old 03-22-2005, 04:53 PM   #6869
fire929's Avatar
Default Shim
Are you shimming the diff or spool or are you shimmimg at the drive shaft cups
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 03-22-2005, 04:56 PM   #6870
You'll need to shim whatever you run...diff, spool, one-way. I use a small shim behind the bevel gears too
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
